View Poll Results: What would you use on a all stock car that is rarely driven? | |||
Points | 25 | 39.06% | |
Pertronix | 18 | 28.13% | |
HEI | 21 | 32.81% | |
Voters: 64. You may not vote on this poll |
Points, pertronix, or HEI?
Sorry if this post has been hashed to death. I just got my dream car, a 1970 Lemans with a 400, and I'm trying to decide if I should leave the ignition system alone (stock), going with a pertronix system under the stock cap, or a HEI.
I would go HEI, but I was concerned about the larger cap and coil fitting under the Dual snorkel air cleaner. Is that a problem anyone has experienced? I'm only going to be driving the car a few hundred miles a year, so I'm tempted to just leave the points intact and check the gap every few years. But It seems all the advice I'm getting is to dump the points. I'd like to hear some fresh opinions and advice |
points...dead reliable need maintenance...on the side of the road, you can probably get home with just a touch of work..yearly check up mandatory...uses a resister wire out of the fuse block...they have issues with age
buy genuine a/c delco, old borg warner, or MSD stuff...buy stuff for a 69 Z28... better stuff hei..dead reliable..good to 5000-ish rpms..when i dies..its dead...a little work on most air cleaners needed..need 12 volts all the time..so you have to run a wire out of your fuse block buy DUI stuff....cheap and reliable...a/c delco cap is about 75 bux now...crazy... pertronix...people rave about them..never used one..never intend to....but when dead..its dead...
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
Thanks for the input. I was leaning toward keeping what I have assuming it's in working condition.
I have a bogging problem at the moment. If the carb doesn't wind up being the problem, I'll look at the Dizzy next |
I have a 72 455HO GTO. I am runnung an HEI for the reliability cause I drive my car alot,but I have my original Unitized Distributor in a box for the next owner to decide what he wants to do.
HEI is my favorite. It is a proven reliable way to upgrade your ignition. No problem with the dual snorkel on my '70
The More People I Meet, The More I Love My Dogs! |
I emailed Lectric Limited regarding your questions on the In dash tach...
Here is my question to them and then below is Dan's reply... You have recieved a new submission from Lectric Limited. The customer's reason for inquiry: ________________________________________ Comments / Non-technical Questions ________________________________________ Name: Kurt O Keller Email: kkeller73@embarqmail.com Comments: BREAKERLESS-SE ELECTRONIC IGNITION CONVERSION Part #: 38131 I have two of these wonderful kits. 1 for my 1968 Camaro and the other for my 1971 LeMans Sport 350. My question is: will this conversion work with a factory installed in dash tachometer on a 1970-1972 LeMans/GTO? Thanks so much for always being at my rescue. I am forever praising this product to everyone I talk with.... Regards....Kurt Hi Kurt, Yes it will work fine. Glad to hear that you have had good experiences with our product Word of mouth is always a nice. Thanks and have a great day. Dan
Kurt L71S....1971 LeMans Sport Coupe 350/TH350 |
Can anyone here confirm this? I've been on the fence about ordering a Pertronix ignitor due to the tach issue and this is the first time seeing the LL kits |
Points - 'nuff said!
Jon
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
Iam having Cliff set up my stock Distributor ...the HEI that is currently in it ...is coming out. Going back to points. Just couldn't get that aftermarket Distributor to do ..what it needs to do.
points.
I have changed my share of hei modules on the roadside. I once had an ACCEL points eliminator in there and I guess it worked ok but I didn't trust it; and went back to points. Gotta buy a few sets to get one good set but that one good set will last for years. Gotta buy the ones with the separate condenser. you can usually make it home with points. Just my opinion. |
if you are talking to me, which i think you are..
no dont buy that DUI distrib..get a used hei and put the DUI cap kit on it... i feel for a stock type driver..points is the way to go..just buy quality stuff..good quality stuff.....like old stock borg warner stuff..its cheap and high end..
Petronix. Had this in my 66 Beaumont for 5 years,no problem whatsoever and kept points in glovebox in case of emergency. Just converted the goat to petronix two weeks ago, I like the no maintenance aspect
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet Th400 gone. Tkx close ratio with .64 of 66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it |
Have pertronix in 3 cars,started using them like 20 years ago with no issue.All have been installed and setup by professional dist people.Last one was Suntuned on this forum.Tom
I use a stock small body factory dizzy with the pertronix kit.Not their dist.Tom
1971 TA factory distributor with pertronix in it. It seemed to run better and haven't touched it in 15 years. Still running 7 volt wire.
Lectric Limited Inc.
Lectric Limited, as far as I am concerned, the best, most OEM looking Breakerless Ignition on the market. I have their ignition on both my 1968 Camaro and also the 1971 LeMans Sport
May want to give them a call... https://www.lectriclimited.com/conve...nversion-85052
that does look interesting, and easy!
And their Tech Support is great as well...They can accommodate the in dash tachs too.
One thing to keep in mind with any version of a modern electronic distributor or transistorized ignition conversion kit is if you have a factory tach that has just one wire from the back of the tach to the "-" side of the coil, the modern ignition upgrade will disable your tachometer. The signal from the conversion kit is different than the pure square wave of the opening and closing of a set of points.
If you want your tach to work: The tachometer will need the circuit board replaced as well as an additional wire added that runs from the back of the tach over to the fuse block. The new wire gives the tach 12 volts of "+" battery power whenever the key is in the on or run position, which is used to power the tach. I am sure that the makers of these ignition system(s) are fully aware of this but it is something that you never see in their advertising.
Peter Serio Owner, Precision Pontiac |
