Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
New best
Went to a track rental. As usual I couldn't get the stuff that I wanted to do done like leaning it out (was 10.4afr), lashing valves, plugs, and reset timing. Anyway, this was leaving off 4.5-5psi with 5° of timing pulled and ramping to 14psi. I made a mistake and had my timing 4° down from where I wanted it. I think it would have ran a 5.6x or better leaner with a couple degrees more timing. Idk. Not hateful for a little over 3,800lbs.
https://youtu.be/jEZde6Ni4mc https://youtu.be/L9thWMSdl58 Last edited by Curtis Slowe; 11-22-2021 at 02:01 PM. |
The Following User Says Thank You to Curtis Slowe For This Useful Post: | ||
What's the setup?
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
469", single TV8513 88mm, sft cam, self ported E heads, 9.3:1, CSU carb, th400, and 3.25 gears. I added a video.
Looking good Ronnie!!!
The Following User Says Thank You to 73 TRANSAM For This Useful Post: | ||
Good work pays off! Nice job.
The Following User Says Thank You to 70 bird For This Useful Post: | ||
Sweet
The Following User Says Thank You to ErikW For This Useful Post: | ||
Nice pass. What fuel are you running?
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
Wow, that's awesome . Nice job on the combo.
Thanks! I spent some time with the suspension and cage this year. Got tired of spinning. It's starting to come around.
It's on 93 pump gas with 1,000ml of water/methanol.
Thanks! |
Good job !
*** THE BIG BRACE is here *** |
The Following User Says Thank You to RUDOLFSSON For This Useful Post: | ||
Thanks! I don't think I've seen you post in a while. Is everything still good with you and your car?
Yes.. not much of a poster these days.
Life is busy with three kids and big house renovations... car is still alive sort of but not in running condition as is -Kris.
Nice pass
Hi Curtis did it run 9.80 in the quarter ? Did you let off because it said 98 mph . Slowe;6296845]Went to a track rental. As usual I couldn't get the stuff that I wanted to do done like leaning it out (was 10.4afr), lashing valves, plugs, and reset timing. Anyway, this was leaving off 4.5-5psi with 5° of timing pulled and ramping to 14psi. I made a mistake and had my timing 4° down from where I wanted it. I think it would have ran a 5.6x or better leaner with a couple degrees more timing. Idk. Not hateful for a little over 3,800lbs.
https://youtu.be/jEZde6Ni4mc https://youtu.be/L9thWMSdl58[/QUOTE] |
[QUOTE=er455;6303354]Hi Curtis did it run 9.80 in the quarter ? Did you let off because it said 98mph.
Yeah, let out at the 1/8. Would've gone 8.9x-9.0x in the 1/4. Last edited by Curtis Slowe; 12-17-2021 at 09:01 PM. |
Nice run
[QUOTE=Curtis Slowe;6303364]Awesome , I have the a very simular setup but I am on E85 , what are you running for timing and are running race fuel ? Are you running a factory block ? I am just wanting to run mid 9 ,s in the quarter with a a full weight 79 trans am with A/c and overdrive (4l80e )
[QUOTE=er455;6303629]
New best
Thanks very nice set up glad to hear it a factory block too that what I have , no not confusing i have my timing locked at 28 at 14 # of boost
Timing retard
[QUOTE=Curtis Slowe;6303640]
Great run! I've not run at Clay City in years, always fun there.
