Old 11-04-2021, 12:49 PM
461-69bird's Avatar
461-69bird 461-69bird is offline
It was all the bolts on the outside of the head that felt looser. The ones inside the rocker covers were tighter.
69 Firebird
472, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 10.90 @123
Old 11-04-2021, 07:08 PM
My old 72 455 HO block the holes were not deep enough on the outside for the Edelbrock bolt to get tight without 2 washers. No problems on my 70 455 block.
Old 11-05-2021, 03:30 AM
461-69bird's Avatar
Skip thanks for that I'll double check the depth before assembly
69 Firebird
Old 11-05-2021, 09:55 AM
It was weird not all of them, but they were on the outside. Edelbrock also on their bolt torque specs uses a different value on the shorter bolts whereas the ARP instructions do not, but Edelbrock uses the same ARP bolts..
