What heads and cam are you running in that bad boy ?
Everything is apparently matched and working together well Good job! It’s actually fairly similar to my car except I substitute the E heads w 70s era smog heads low compression and 11 psi boost 373 gear and a tight 3000 converter but still fairly similar. Does the same thing just gets there a little differently.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
E-head that where ported by Kauffman about 10 years ago. 72 cc flow 330 at .700. The cam is a Comp cam 278/282 at .050 lift is .652/.658 ground at 108 and installed straight up. Compression is right at 12.0-1.
I had a valve job on the heads last year and the machinist ground them with a 38 degree seat on the intake. Ever since then my 60's have been great. Usually 1.35 for a 10 flat. |
Sounds like it is time to go e85!
Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
How high do you have to spin it ? 445 block or 400 ? I hope you don't mind the questions. Building a engine not unlike yours myself. I hope it runs as good. Trying to do the same thing. 10 flat, see how far it can dip into the 9s before I upgrade the cert. |
No problem. It is a 70 455 block out of a big car. Put aftermarket 4 bolt main caps with studs. I is a forged 455 crank. I shift at 6400 and go thru the traps about 6800 at 134.
If I want to run it all. out thru the 1/4 I will need taller tires or a 3.90 gear |
Thanks for sharing the information. How tall of a tire are you currently running? I am running a 4:10 gear and I am looking to go with a taller tire. I am currently running a 29" tire.
Thanks, Joe |
30.5" radial with the 4.10 gear
Thank you. I was looking at getting a 30.5". That is probably the tallest that I can fit.
You running motor mounts or engine plates?
motor mounts with dog ears off the heads.
I plan to hit Capital Raceway (Maryland) this upcoming Saturday (11/20) with forecast temps ranging 27 - 48. This is using drag MT drag radials...doesn't look like any sunshine Saturday...
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
