Replacing inner tie rods -65 GTO
Due to clearance issues when greasing I plan to replace my inner tie rods with ones with the grease fitting on the end. My current ones have the fitting on side, which is a PIA to grease. Is it general practice to replace both inner and outer at same time, or am I ok with just doing the inners?
Unless the car is in a wreck, hits some major road damage etc. the hard parts typically aren't the concern, it's the joints. I would inspect the entirety of the steering linkage for worn joints, slop etc. If it's all in good shape, you can certainly replace only the inner tie-rods.
You may find however if it's stock equipment, that a total steering rebuild might benefit how the car drives.
Thanks JLMounce. The rest of my suspension is in good shape, so I’ll just install the inners, so my grease fittings are in a more accessible location.
Instead of replacing good parts just replace the fitting(s) with 90 degree one(s).
The Following User Says Thank You to Goatracer1 For This Useful Post: | ||
Tried the 90, it hits the frame.
Per the Ames catalog, the originals had the fitting on the end, so mine are incorrect. Had the car 30 years and still learning stuff!
I bought a box of zerks from Ebay , the 45 degree might work,
James Q
James Quayhagen 1963 Bonneville Safari - Nocturne Blue, 4-speed |
Thread Tools | |
Display Modes | |
