Old 11-10-2021, 05:40 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Default Identifying crankshaft?
I have a crank with center counterweights. I can't find any type of markings on it. Is there a way to identify the manufacturer?
I need a new aftermarket block. This crank has 3.25 mains. I'm assuming I can have the mains cut down to 3.00?
www.lancablingsolutions.com
Old 11-10-2021, 05:50 PM
Tom Vaught's Avatar
Boost Engineer
At one time there were several top notch Crankshaft Machinists in California.
Without a receipt or a marking on the crank, it would all be a guess. A Wild Guess.
Tom V.
Old 11-10-2021, 07:19 PM
73 TRANSAM 73 TRANSAM is offline
Default crank
Looks like a Moldex crank finished by RHS. Butler sold those crank, looks like a cross drilled crank.
Old 11-10-2021, 07:47 PM
Tom Vaught's Avatar
Boost Engineer
All of the Cranks that Moldex produced years ago for Butler performance (5 cranks at a time ordered) were completely finished when they were shipped. I was there when they were being made. Whitey was the Shop Foreman. His son owns the place now. Whitey, RIP.
So I say BS on RHS finishing the cranks. Moldex always identified their cranks too. No Moldex Crank Stamp (but other ways).
My opinion not a Moldex crank. Moldex also did Straight Shot oiling on those cranks. Not normal Pontiac oiling.
Tom V.
Old 11-10-2021, 08:49 PM
Default crank
Not trying to argue Tom V . My buddy damaged his crank and it is indeed a Moldex but was finished by RHS and was sold thru BP. It is also a cross drilled crank. He sent it to Moldex and they did say it is their crank that was sold thru Butler unfinished. They couldn't repair it as it cracked from the oil hole after he broke a rod. Just trying to help a fellow PY member.
Old 11-10-2021, 11:55 PM
Tom Vaught's Avatar
Boost Engineer
Would have been nice to have post # 5 in the first place.
The cranks I saw DONE by Moldex were FINISHED Cranks, not a part that RHS machined most likely after Bob Gillian
sold Moldex to Joe Flowers, Jr. So it was a roughed in crankshaft.
It probably was not as strong either if the crank did not go thru ALL of the Steps that Moldex used to perform on their
finished in house cranks. Nitriding being one of the last steps. Probably would have not been damaged in that oil hole
area if Moldex had finished the crank themselves. Their detail work was excellent.
It just took Moldex a lot longer to kick out a crank when they went from a 30 man shop to a 3 man shop.
Always better in the beginning to give all of the details you are aware of vs make a short generic statement.
Like it was a Butler/Moldex crank. It was but it wasn't, was it.
Tom V.
