Old 11-16-2021, 05:35 PM
Dragncar Dragncar is offline
What heads and cam are you running in that bad boy ?
Old 11-16-2021, 06:51 PM
turbo69bird's Avatar
Originally Posted by Mike S View Post
Yes NA. It's your basic combo, stock block e-heads that flow 330, victor, 1050 holley, th400 with 8" converter. 4.10 gear in a 12 bolt. Suspension is all stock. Moved rear lower trailing arm down 3/4" on the rear. Double adjustable coil overs on the back and stock replacement shocks on the front. Car is 3200lbs with me in it.
This combo took years to get dialed in especially the suspension. I never ran it all out in all the years I have been racing it. I am always trying to go 10.00 for index races. I never thought it would run a 6.0 in the 1/8.
Wow that’s really impressive for that combo .
Everything is apparently matched and working together well
Good job!
It’s actually fairly similar to my car except I substitute the E heads w 70s era smog heads low compression and 11 psi boost 373 gear and a tight 3000 converter but still fairly similar.
Does the same thing just gets there a little differently.
960 HP @ 11 psi, 9.70 at 146.
Old 11-16-2021, 07:32 PM
Mike S's Avatar
Mike S Mike S is offline
E-head that where ported by Kauffman about 10 years ago. 72 cc flow 330 at .700. The cam is a Comp cam 278/282 at .050 lift is .652/.658 ground at 108 and installed straight up. Compression is right at 12.0-1.
I had a valve job on the heads last year and the machinist ground them with a 38 degree seat on the intake. Ever since then my 60's have been great. Usually 1.35 for a 10 flat.
Old 11-16-2021, 08:19 PM
leeklm's Avatar
leeklm leeklm is offline
Sounds like it is time to go e85!
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 11-17-2021, 02:02 AM
Thats a nice combo. its obvious how much work you have put into your engine and car.
How high do you have to spin it ?
445 block or 400 ?
I hope you don't mind the questions. Building a engine not unlike yours myself. I hope it runs as good. Trying to do the same thing. 10 flat, see how far it can dip into the 9s before I upgrade the cert.
Old 11-17-2021, 08:36 AM
Mike S's Avatar
No problem. It is a 70 455 block out of a big car. Put aftermarket 4 bolt main caps with studs. I is a forged 455 crank. I shift at 6400 and go thru the traps about 6800 at 134.
If I want to run it all. out thru the 1/4 I will need taller tires or a 3.90 gear
Old 11-17-2021, 10:00 AM
421 Bird's Avatar
421 Bird 421 Bird is offline
Thanks for sharing the information. How tall of a tire are you currently running? I am running a 4:10 gear and I am looking to go with a taller tire. I am currently running a 29" tire.
Thanks,
Joe
Old 11-17-2021, 11:16 AM
Mike S's Avatar
30.5" radial with the 4.10 gear
Old 11-17-2021, 11:47 AM
421 Bird's Avatar
Thank you. I was looking at getting a 30.5". That is probably the tallest that I can fit.
Old 11-17-2021, 09:41 PM
slowbird's Avatar
slowbird slowbird is offline
You running motor mounts or engine plates?
Old 11-18-2021, 09:45 AM
Mike S's Avatar
motor mounts with dog ears off the heads.
Old 11-18-2021, 02:04 PM
grivera's Avatar
grivera grivera is online now
I plan to hit Capital Raceway (Maryland) this upcoming Saturday (11/20) with forecast temps ranging 27 - 48. This is using drag MT drag radials...doesn't look like any sunshine Saturday...
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
