Old 11-20-2021, 09:11 PM
arbys's Avatar
arbys arbys is offline
Default Convertible top seal installation
I'm installing a new header seal on my 66 LeMans convertible. As seen in the pictures the seal extends about 1/2" beyond the screw holes. There are about 12 nylon pegs embedded in the rubber seal. The pegs aligned good. Do I re drill a couple of holes and move the over to align with the screw holes or exactly what should I do?
ID:	578244   Click image for larger version
Old 11-20-2021, 11:53 PM
squidtone's Avatar
squidtone squidtone is offline
arbys,
What brand was that seal?
I used "Metro" brand 8 years ago, and it fit very nicely...
If you do drill new holes, I'd worry that the too-wide seal will extend too far outboard on each side...and the front to back seals won't match up well with the stretched out header seal...
Dave
http://www.squidsfabshop.com/?
(updated January, 2013, Pypes exhaust installation)
Old 11-21-2021, 01:14 AM
fyrffytr1's Avatar
How would it work to screw the ends down first then do the pegs?
Old 11-21-2021, 02:24 PM
arbys's Avatar
Upon closer inspection (daytime) I noticed that there were little slits where they installed the pins. All I need to is align the pins with the holes and then install the "T" shaped pins in the molding.
Old 11-22-2021, 07:28 PM
arbys's Avatar
Today I removed all of the nylon pins from the front seal. I attached the top seal with two of the screws on the ends and then closely inspected the position of the top seal with the predrilled holes and inserted a scratch awl to mark the spot where the pin had to be inserted. After I did that I inserted the pins from end to end. Virtually non of the pins original were in the correct spot.
Old 11-22-2021, 08:10 PM
squidtone's Avatar
hopefully your solution works well. It's too bad it was so far off.
Aftermarket parts. Sigh.
Dave
