71 Judge, M-22 WO.
I was told my Judge's M-22 WO had the the WO stamped, it does, but I was told to look for the vin on the trans. But I have had so many people tell me different place's the vin is supose to be. Some say on the right some say on the top. I haven't pulled the trans out to look yet and it does have the metal tag as well. I was just curious because i hear 2 different stories about the vin. I have heard some say they have seen them both ways, I didn't know if it was because of different plants or year change? My car is a last week Jan. 1971 455 Ho. from Fremont, Cali. I have all the PHS Doc's.
Thanks for anyone's help. |
Trans
You heard right, could be either way - passenger side or top. Try a search. Perhaps Fremont in 1971 was always the same.
1969 Judge, 4-speed, CR/Parchment, Quasi-Survivor, #'s match - under restoration |
I had a M22 71 HO car from Fremont. OVERULD now owns car, it is a numbers car with a correct date, and has no vin stamped where it should be.
I heard other Fremont car were that way on the trannies. Maybe that is why you can't find. More details on the 71 Judge? Colors, options, pix?
Mike/Illinois |
mine is stamped on the side on the piece between the tail shaft and the body and the 2 letter code was on the top.
What was your car? Is it also a 71 GTO or Judge? I don't know if the m-22 is different then any others. I have seen the vin stamped beside the date code and under the date code on others, I just didn't know about this one. I am planing on crawling under it tomorrow to try to do some searching. Thanks.
Mike: When you replaced the clutch in 2005 - did you look at the top of the tranny when it was out of the car to see if the VIN was stamped up there? Take any pictures? Would love to have them if you did and still have them?? BJ
1971 GTO 455 HO 4-speed - Cameo White, White Vinyl Top, Jade Green Interior, Ram Air Hood, AC, Honeycombs and 8-track 1974 Formula 455 I Owned in 1975-1976. Now Own Its Twin From Same Dealership |
BJ, I had the mechanic do the clutch so I never have seen the top of the trannie. All the M-22 I've seen is the vin is visible.
Mike/Illinois |
Ditto to that, on the passenger side stamped vertically.............
I have a WO M22 out of a Van Nuys built 71 TA. The vin is stamped on the top surface of the tranny. I always thought they should have been stamped where motorcitymuscle says, but I suppose different plants could have done things differently.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
Here's a shot of the 71 ho I'm currently doing the vin ect is on the side, build date is around 4-71
BJ PS: What does the WO stand for? That's a new one to me.
1971 GTO 455 HO 4-speed - Cameo White, White Vinyl Top, Jade Green Interior, Ram Air Hood, AC, Honeycombs and 8-track 1974 Formula 455 I Owned in 1975-1976. Now Own Its Twin From Same Dealership Last edited by OVERULD; 01-23-2009 at 12:00 PM. Reason: Added PS |
FWIW - the "WO" M22 in my 12C '72 GTO (Pontiac plant) has the VIN stamped in the usual location - vertical, passenger side.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
BJ
Hey Mike, I couldn't find a VIN on my M22 72 lemans out of that plant either....now this makes sense to me. glad I stumbled upon this info. Pat
Pat Brown |
The M22 on my 72 GTO from Pontiac plant has the VIN stamped in it.
Pat Brown |
Pat, My 71 Pontiac built Judge that has the M-22. The VIN stamped in the place where it should be.
Mike/Illinois |
BJ
I have pictures of various year transmissions from original cars. A 1969 Judge transmission has the VIN stamped on the "top" of the transmission (as viewed from above imagining it installed in the car) on the "ears" and back "rib" of the main case too. I won't post as the owner has not yet given me permission.
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
My Judge has the VIN stamped on the side of the trans and it was also built the last week of January out of the Fremont plant. The WO stamp is on the top of the case and the VIN is on the passenger side of the trans and its verticle.
Marksrods what day was the car made? just curious to how close it is to my car, mine was built on the 27th of January. |
