Upper Radiator Hose Detail(s)
I’m looking for input on the proper detail markings on a 1970 GTO upper radiator hose. I’ve seen a few with a pale yellow stripe and others with a blue stripe on the top of the hose running the full length. Most of them have the part number stamped in white near the radiator end. Any input on correctness is appreciated.
Those ones on epay are incorrect. Ask john at motorcitymuscle.
What's wrong with them? Can you get correct ones?
The yellow stripes with the part # is correct with the stamp that has the arrow and says "to radiator". It does not say GM on it. Check with john at motorcitymuscle, i'm sure he has some good pictures.
contact henley, not to knock inline AT ALL but i think hes more of a 69 GUY like me
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored) 1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505 1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS AC Cobra Kit Car 521 670 HP/715 Trq LOOKING FOR V PARTS !!!!!!!!!!!! |
I've attached a few photos of the stripe and markings I'm referring to. Unfortunately I could not find any photos of ’69 or ’70 Judges with these details. The photos are of 1967 Corvettes. At this year’s POCI Points Judging there were a few cars with similar stripes. I did not have any points deducted for not having the markings but if they are correct I want to replicate them.
The hoses that i have seen that are original always have a stripe - have seen it in white and yellow. The stripe is broken every few inches for the date code of the hose, and at the radiator end it has the arrow with part number and says radiator. This was there to direct the assembly line worker which direction the hose went. Inline tube sell the radiator end stamp. The hoses most sell with the GM and part number in white in the center of the hose I have never seen just like the GM heater hose. The picture is a low mile GTO -look at the hose - sorry it is small
The 69 assembly manual also states to place the "hose with the arrow to the radiator" suggesting the hose has an arrow as stated. Just another reinforcement for an arrow.
Thanks for the input. I went back and looked at the restoration photos of the Cardinal Red Ram Air IV Convertible restored by Scott Tiemann. That car has a blue stripe with the radiator arrow stamp and GM Part number in yellow. I’ll go ahead and buy the radiator stamp from Inline Tube. What is the best paint to use for applying the stamp and stripe? |
I use red devil latex paint or similar as you will do quite a bit of stamps to get the right effect and the stamps are rubber. Oil based paints need solvent to clean them up and will attack the stamp and ruin it very quickly. Soak a rag with simple green or spray nine and as soon as you stamp your hose clean the stamp asap since the paint will load it up. Thats how I did all mine. Regarding the stripe color, I had mine done in blue but I have seen yellow and white too on the 69's and 70's.
The rad hose thing is an item one of the parts houses like our host, ames or inline should jump on to make and sell a correct, stamped, striped hose, It's long overdue and it doesn't seem like it would need a big outlay at all for the equipment to make correct striped stamped hoses either. How about you John? They would compliment all your stamps and other detail items for sure.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming. 67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project. Last edited by Mark Simiele; 01-27-2009 at 11:58 AM. |
I have the hoses here and was thinking about doing it but it is time consumming and plenty of the other guys have the wrong hose for sale for $20.00 and when mine is $25.00 nobody buys it. So I sell the radiator end stamp with the arrow and the stripe you have to put on yourself. You can buy the stamper and use it and lend it to all you buddies.
I would research that blue hose stripe more - I know Tieman like to use it but i have never seen it on a 69-72 it might of been on the earlier cars 64-67 but not on the later. |
Thanks |
Unfortunately, I can't guarantee if this is original or not, but this came off a late '70 w/original radiator. As you can see, it has worm clamp marks on it (but also what I believe to be the tower marks). I saw no other striping or marks (I take that back, there were molding marks and I can get a picture of that, if needed).
And, I don't believe Inline's stamp would be correct for '70. |
hoses..
I have a yellow stamped one.. I thought the yellow ones were GM replacements.. White was period correct
How does GTOAA Concourse Judging evaluate this level of detail? Like I mentioned earlier, POCI did not deduct any points for my engine compartment. I'm planning on competing in both POCI and GTOAA Points Judging this summer.
It all depends on the judges, most likley there would be no point deduction for hose markings but every detail and point gets you closer to the gold. If all the cars have the markings and yours does not it may be a deduction. There is no set rules that are that specific. I think belts and hoses are worth 5 points. I would make sure the hoses are the correct shape at least and you did not use cogged belts and you will be fine. The markings are a bonus and seperate your car from the rest.
Ditto on what John said. All my stamps, decals, stripes, over spray and markings got me no extra points and I knew that but they just look great.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming. 67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project. |
