Sorry, no paperwork on the heads or engine.
As far as the engine I traded for it and it had been freshly machined and assembled but it sit for a few years. I put it on an engine stand and just checked all of the tolerances and cleaned everything up. I bought the 2802 cam myself and put in there. I have the cam card for it around somewhere. It has speed pro rings and bearings. The rods are stock cast. Pistons are cast factory replacements with the dish. The 12's have had a valve job and would put the engine right at 10:1 compression. The crankshaft was turned .010. It has the factory 3/4 windage tray. I don't currently have the push rods in or the valves adjusted at the moment, so that would certainly need to be done to finish it. It's a 2 bolt main YH code block. Certainly not out to cheat anyone on it. Not something that I have to sell or need to sell, I have a couple of other 428's and just built a 428 with ram air 4 heads and just don't see myself using this one with the 12's for a while. The 1st picture attached shows the engine with a '65 tripower and the long branch manifolds. I will be keeping those at $2,000. The second picture is the primary reason this one would be for sale. Any other questions or picture needed of the engine I am happy to help.
