Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
3/8-24 all threaded bolt Grade 8
Long story short, got my umi lower control arms, they supply a 4 inch bolt to hook you end links into.............seems i need one maybe 5-6 inches long. Umi suggested getting a longer bolt.............so far i cant seem to locate one, not sure im putting the info properly in the puter...........can anyone help out here.
Just to be clear, it must be all thread Rich |
Not likely to find a bolt like that.
What about a piece of all thread. You could tack weld a nut on 1 end. or use red lock tight. JM2C's |
When I was on that page it had them to 6" or so?
EDIT: You are right, after a certain length they went to partial. Try this for the all thread: McMaster-Carr
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates Last edited by johnta1; 04-14-2021 at 07:25 AM. |
Although "all thread" type rod can be used and will work, it shouldn't be necessary. When you are building up your "sandwich" of the 4 bushings and washers, it often looks likes it's impossible to get a nut started. However, the "sandwich" is operated in tension. Have an assistant with a long bar pry down on the stabilizer bar near the end and then you can usually get the nut started. once started, it will quickly compress the bushings and go together without leaving a long, ugly stud end hanging out. Good luck.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
Hey Mike, i"ll send you a email on what im doing
Rich |
Another thought on this, can you take a longer partially threaded grade 8 bolt and have a machine shop make it into a full threaded bolt.
Rich |
Fastenal lists a 5 1/2" but calls it a tap bolt.
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
Hey Jim, ive seen that in the Fastenal book, but that is a grade 5...........not sure if this is strong enough for the end links....pic of what i have going on here.
Rich |
I see now. I assumed you had stock links. I think 3/8-24 hardened all thread rod would work fine in this application.
Now I see .... if you absolutely cannot find the right bolt ... I'd use the grade 8 rod with a nut TIG welded to the top.
Hey thanks Mike & dataway...............i can get the threaded rod but they said two weeks out.............i did find a 5 1/2 grade 5 at Fastenal.........any thoughts on that one.
So i take it you cant take a longer grade 8 bolt that is partially threaded and get a machine shop to make it into a total thread. Rich |
Thread Tools | |
Display Modes | |
