What to do now / Dynacorn Hood
Purchased a new Dynacorn hood for my 1970 T/A that is defective. The dealer I purchased hood from told me Dynacorn has terrible service after the sale and will not help you. I wrote a very clear email to Dynacorn 5 days ago concerning the issue and sent 4 detailed photos as well. I also called Dynacorn 3 times now to confirm that they received email and to ask when someone would be calling me to help resolve the problem. The customer service rep told me they would get on my case right away but so far "crickets". It is looking like I am going to get screwed by Dynacorn. My question now is: can this hood be repaired or do I have to try and find a good used hood? ( I realize that the body shop that completed the paint and body work "should" have fitted the hood before paint and they said they did, but obviously they did not.) Suggestions?
1970 T/A |
I am not a bodyman but at this point I would bodywork the endura nose to match the hood and repaint it. It should be possible to match the paint after bodyworking the nose. But if it came out slightly off color that would not be unusual anyway.
That and the hood could be gently flattened at the front some to help reduce the work needed to the nose. It is the paint shop you need to harass more so than the parts supplier Last edited by nas t eh; 03-12-2021 at 10:50 AM. |
My body guy spent many hours fitting the hood, bumper, nose, fenders, etc., on my birds and everything was OEM. I suspect the aftermarket hood will need more work, and a good shop should be able to advise you as to whether it's cost effective to fix that one vs. finding an original. I think you're either going to have to work with the body shop that did the work or find another one.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
I don't think that could be fixed to my satisfaction. The 'peak' of the hood is off center in relation to the peak of the bumper. Even if you worked the bumper, you'd have to do it all the way down to the bottom. Same with the hood...if you 'move' the peak, it would have to be done all the way from front to back...then it may be noticeably off center from the shaker opening.
I'm no expert by a long shot though... We have some here though and I'm curious as to what they have to say.
Greg Reid Palmetto, Georgia |
As the fit looks worse on the drivers side I would make a template just for point of information. Get a piece of cardboard and fit it in the slot between the hood and nose. Without scratching the paint scribe a line of the hood contour onto the cardboard. Cut on the line and then refit the template to the hood with the ends reversed side to side. If it happens to fit in the reversed position then it would seem that the hood might be good and it is the nose that needs reworked. That nose material could get a little squirrely anyway and if it has been sitting in a pile for a while while other work was done who know what may have happened to it.
I measured the endura nose and it is true with no sags or dips in the material. I believe Dynacorn messed up when they welded the lower hood panel to the upper hood panel which allowed the center/front section of the hood to sit up way too high. Thanks for the input.
1970 T/A |
I would start by blocking up the outside and trying to carefully push the center down. after my GTO was painted I was initially convinced that there was no way in hell everything was going to line up. But after hours of adjusting it all did.
The Following User Says Thank You to JSchmitz For This Useful Post: | ||
Problem 1: Chiwanese parts are sub-substandard and you always get what you pay for. Never expect them to fit or act like OEM regardless of what anybody says.
Problem 2: As stated, bodyshop screwed up. Car should have NEVER been painted until panel fit was right. Kinda makes one wonder about the rest of their work under the paint. Granted photos don't show true story but from what I can see it seems as though some creative jockeying around and shimming should make most of that go away. Your chance at a 100 point show car went away with the Chiwanese parts. Now you just need to make due and live with it or redo the restoration using only NOS or OEM parts. Bottom line, lesson learned and you still have a decent car. |
Just had a similar issue with a 78. I was able to resolve it by loosening the screws that hold the urethane skin to the bumper frame and pulling the skin up. I can’t remember if the early second gen bumpers have the same screws. It’s been several years since I built one. You can also recess the latch a skooch lower to take a bit of the crown out of the hood. Between the two you should able to make it work. Don’t give up yet.
Don |
I have fixed this very issue on the exact same hood for my car. In a post below JSchmitz suggested to support the two front corners and push down on the center. Do not do this with a bird hood. If you push down from the top you will get outtie dents from the underside bracing pushing up.
To fix mine, I chained from the center hood latch area on the core support to the hood latch underside bracing with a chain with hooks, and used a scissor jack at each corner to push up. Be very careful and go slow. You will have to over shoot and let it spring back. If you go too far, you may buckle the skin. As a disclaimer I did this before paint, but had no issues with the hood buckling so no special bodywork. The 1st hood I bought I pushed down from the top and created 2 outie dents. I dollied the dents out, but I made the skin weak and the under bracing ended up too close to the skin. Every time I closed the hood the outie dents would reappear. Here is a before and after picture. |
That can be fixed but should have been long before paint. Passenger side isn't to bad, the drivers side will need the most work. I'm sure that corner could be bent up so you can lower that hood edge
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
1970 GTO (Granada Gold) - 400 / TH400 |
Don’t want to hijack the post but.....
I worked with Jason Rushforth to design and make the wheels. Fronts are 19x10 and rears are 19x13. I made the center caps myself to use NOS PMD hubcap centers I think they scale up nicely. |
The Following User Says Thank You to Stan65 For This Useful Post: | ||
Apologies for the hi-jack...I thought they were Rushforth's.
This is my favorite rendering of the Night Trains...and an inspiration.
Thanks for all of the replies! I will share this info with a new body man and see if he wants to give it a shot. Thanks again.
1970 T/A |
Looks like the hood latch needs adjustment,to bring the hood down . Then loosen the 2 bolts on the Radiator support and shove it over to line up the peak of the hood and cover. If that don’t work ....measure your frame rails ,it may need a tug.
I guess I can't see straight. You guys are talking about the hood being too high...it sure looked off-center to me.... Carry on...
Both and totally compensatable.
The Following User Says Thank You to Chief of the 60's For This Useful Post: | ||
put some loosely crumpled tin foil on the fan shroud and close the hood. It will tell you it it is hitting the fan shroud and only take 2 minutes.
