Old 03-05-2021, 02:17 PM
scott70's Avatar
scott70 scott70 is offline
Default 70 gto rear lower door panel
The plastic panel has a piece of metal screwed to it that runs up to the rear package tray. I put the screws in through the metal sideways and goes through the vinyl door panel. The top of the metal rests against the rear bulkhead. Question is does the top of the metal just rest against the bulkhead or does it attach somehow. Seems to be a little floppy to me and the factory would of attached it somehow but I don't see any holes that it would.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 03-05-2021, 05:21 PM
Jason67's Avatar
Jason67 Jason67 is offline
Scott, no screws from the metal filler towards the rear. Just the 2 going thru the door panel on the side, and the 2 at the bottom to the plastic arm rest.
Name:	filler piece.jpg
Jason
Old 03-05-2021, 05:26 PM
vertigto's Avatar
vertigto vertigto is offline
What Jason said...be careful not to crack the plastic side panel when installing (or removing).
Old 03-05-2021, 05:59 PM
scott70's Avatar
Thanks guys,,,thats what I was looking for. Just looks like the top should be hooked to something.
