Old 03-08-2021, 11:59 PM
tom s tom s is offline
Default 301 power steering mounting
Has anyone ever tried mounting the power steering on the drivers side of the engine and the alt on the pass side?I have the alt mounted but can't seem to find a bracket to work with just the PS.Tom
Old 03-09-2021, 06:44 AM
Aus78Formula Aus78Formula is offline
No need if you have the correct brackets, you just install as designed.
Old 03-09-2021, 10:45 AM
78w72 78w72 is offline
is there a reason you want/need to do that? the p/s is already mounted on the driver side & as mentioned, with the right brackets both will mount there as the factory did.
but if you want to put the alt on the pass side then just use the stock brackets to mount the p/s pump as designed... if it will fit with your set up.
Old 03-09-2021, 11:41 AM
I dont want to use the stock alt-PS bracket.Trying to save room on that side of the engine.Tom
Old 03-09-2021, 11:57 AM
Figured you were trying to balance the accessories out with the alt on the pass side. Very interested in the progress youre making with the short deck RA5 engine!
Throw this out Tom, if you do have to source 301 PS brackets, the '77-79 301 used the common 10 SI alt, & its own style of 301 alt/PS mtg brackets (thankfully, the most common). For '80 models, a larger size 15SI alt was optional, & required its own style of brackets, one being an alum bracket (pivot block). Have picked up numerous 301 Alt/PS brackets mixed up over the years in partscar deals, & often took some sorting to identify what I was looking at.
Old 03-09-2021, 12:09 PM
Here is where I’m at right now.
Old 03-09-2021, 12:13 PM
Alt lines up perfect.The PS is a issue,still working it out.If I can figure out how to make it adjust I can just cut all the Alt stuff off the bracket.Issue is the mounting pattern on a V heads is a little diff and can only use two of the bolts after inlarging the holes.I have mounted both on the drivers side before but with the shorter deck,it gets REAL tight getting a fuel line up,will be REAL bad with the Cross Ram intake.tom
Old 03-10-2021, 06:48 PM
Think I got it,used a 61-64 PS bracket with some mods.Will know when I get the pulley.Tom
ID:	562434   Click image for larger version
ID:	562435   Click image for larger version
