Old 03-11-2021, 09:01 AM
Yellow Bird Yellow Bird is offline
Default Alternator Question
Does anyone know how many amps the 10SI series alternator put out in the 1977 Trans am? I want to do a rebuild on it and don't know what to order. There's no air conditioning or power windows but I still want to refurbish the alternator to original. Suggestions for a quality rebuild kit would be appreciated. I want to keep the original.
The Following User Says Thank You to Yellow Bird For This Useful Post:
Old 03-11-2021, 10:03 AM
stellar stellar is offline
The original should have the amps stamped on the case. Without AC probably 37A or 42A
The Following User Says Thank You to stellar For This Useful Post:
Old 03-11-2021, 12:01 PM
shermanator2 shermanator2 is offline
According to Wallace racing, without AC or rear defog, 37A. If you have rear defog, then 55A. I have had good luck buying alternator parts from https://alternatorparts.com.
The Following User Says Thank You to shermanator2 For This Useful Post:
Old 03-12-2021, 09:09 AM
Mike Davis's Avatar
My local NAPA got the parts I needed to rebuild a few of mine.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
