Old 03-11-2021, 04:08 PM
Hooter's Avatar
Hooter Hooter is offline
Default 65 Door Hinge Adjustment - Fender Removal Needed?
After years of racing before adding the roll cage, the body on my 65 is a little tweaked and I need to adjust the drives door. Are there any secrets to getting to the hinge bolts without removing the fender?
67 Bonneville ragtop
Old 03-11-2021, 08:52 PM
Cardo's Avatar
Cardo Cardo is offline
It depends on how you need to adjust it....there is some up-down in - out adjustment on the hinge to door connection with the phillips head screws going into the door. You may be able to get what you need there.
"I know just enough to keep me here, but not enough to get me out"
The Following User Says Thank You to Cardo For This Useful Post:
Old 03-11-2021, 09:53 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
There used to be door hinges wrenches available, but can't find them now. s shape wrenches to go thru the opening and adjust the front part of hinges.
Some old timers may still have some hanging around. LOL. We are all getting to be old timers, LMAO. Sometimes they offset on one end, usually 1/2 inch
and 9/16 wrenches. I believe the bolts are 1/2 inch.
64 Lemans hardtop
4spd, buckets
The Following User Says Thank You to Lemans64 For This Useful Post:
Old 03-12-2021, 08:28 AM
Hooter's Avatar
I need to adjust the door up about 1/4”. Never thought about trying to adjust from the door side. Will check that out. Thinking along those lines, bet it would be easier to remove the door and make hinge adjustments(be kind of a guess as you go).
I did come across that s shaped tool. There’s one on eBay. I might have to buy it but dang they’re pricey.
Old 03-12-2021, 09:04 AM
Cardo's Avatar
I just adjusted mine like you need yours... I was able to do it off of the door to hinge like i described. You don't need the door super loose, and used a floor jack at the back end of the door to help - don't get crazy with the jack though.
Old 03-12-2021, 10:23 AM
Lemans64's Avatar
You can use a Hex bit ratchet to loosen those screws, they are slim so they fit in there easier.
Been there done that. There is quite a bit of adjustment there.
64 Lemans hardtop
4spd, buckets
Old 03-12-2021, 08:18 PM
geeteeohguy's Avatar
I got a whole set of the S and C shaped wrenches from Harbor Freight. Made door adjustment a snap with the fenders on. ('67 GTO). Check HF out. The sets were less than $20. Decent quality, too, which was a surprise.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 03-13-2021, 12:42 PM
Hooter's Avatar
Between adjusting the Phillips head screws going into the door and dropping the striker a hair it’s much improved and latches much easier. I can live with it as is but am going to check out China Freight as suggested. Thanks for all the advice fellas.
Old 03-13-2021, 12:49 PM
dld's Avatar
dld dld is offline
Old guy tool box draw .
Old 03-16-2021, 08:13 PM
Hooter's Avatar
Well, I was able to adjust it with this wrench I found at the farm store. It’s not very long for leverage, but I replaced the hinges when I painted the car 20 years ago and the bolts came loose fairly easily.
