Old 04-06-2021, 08:23 PM
Buck Wilde Buck Wilde is offline
I used Guru Colors by Thornton Restorations on a 67. I thought it looked great and sprayed out very similar to the factory finish.
The Following User Says Thank You to Buck Wilde For This Useful Post:
Old 04-07-2021, 10:14 AM
Firedup6975's Avatar
Originally Posted by tjs72lemans View Post
Did you use that on a black or grey trunk color?
We bought the Dupli-Color spatter and it mostly just aqua glitter with very little black in it but some. We didn’t like it so left it as a primer base and used the AC stuff over it. Left it dry over night, then clear coated it. Still haven’t put anything back in the trunk yet letting it just get air.
~MaryAnn~ AKA "Stickybuns"
1969 Firebird 400 Convertible
1978 Bandit T/A Tribute
1977 RED TA
I'm the FiredUp PY bad girl
Old 04-07-2021, 10:17 AM
We’re very happy with it, looks just like factory.
1977 RED TA
Old 04-07-2021, 08:06 PM
Sounds like you used a grey primer then?
Old 04-07-2021, 10:57 PM
400 4spd.'s Avatar
Originally Posted by Firedup6975 View Post
Bought paint from inline tube, and it’s exactly like it should be! we sprayed the color on Saturday, and the clear on Sunday.
Would you mind getting a close up picture under direct sunlight and posting it? Maybe lay a coin down for size reference?
Thanks!!
Old 04-08-2021, 10:42 AM
No we used the Dupli-Color that didn’t match well as the primer. When we sprayed it, it was more like a black base with aqua glitter in it. So we left it as the primer, and used the Delco paint over it, and it is perfect now. Sprayed very easy and consistent.
1977 RED TA
Old 04-08-2021, 10:44 AM
Thanks!!
The pics I posted were in direct sun.
1977 RED TA
Old 04-08-2021, 10:45 AM
Black/Aqua the Grey/White is not correct for the 77.
1977 RED TA
Old 04-08-2021, 01:44 PM
400 4spd.'s Avatar
Translation - what color was your trunk before you spray bombed it the first time with Duplicolor?
Old 04-08-2021, 08:06 PM
The original aqua/black was still in it, but starting to wear off and fade. We did not strip the old stuff off, just a light sanding and clean, then used the Dupli-color and left it as the primer and used the AC Delco stuff. BTW this is the same AC paint in my 69,s trunk.
ID:	564337   Click image for larger version
1977 RED TA
