Old 04-05-2021, 12:14 PM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
Default Should I replace the water tubes?
I noticed my car had a small leak on one of the water pump bolts. I had a spare waterpump with a cast impellar lying around so I figured lets pull the water pump and fix the leak.
So old pump has a stamped impellar and the gap between the impellar and divider plate was huge. I cleaned the divider plate and made the clearance a bit tighter and started looking at the water tubes. So when do these need to be replaced?
One is stuck, the other came out by hand.
The block is a 67 400 by the way and has the 8 bolt water pump.
ID:	564123   Click image for larger version
ID:	564124   Click image for larger version
1968 - Pontiac GTO
Old 04-05-2021, 02:07 PM
ZeGermanHam's Avatar
If the rubber o-ring seals on the sleeves are old and hardened as your appear to be, I'd get some new sleeves & seals. I'm not sure if you can purchase the o-rings separately, as I've typically seen them sold together, but you might be able to. As far as the stuck sleeve goes, I imagine you can get it out with a bit of persuasion.
1998 BMW 328is (track rat)
Old 04-05-2021, 02:26 PM
I can't count to 11 anymore it seems..
Ok I'll replace the tubes then. Thanks for the advice.
1968 - Pontiac GTO
Old 04-05-2021, 03:34 PM
george kujanski's Avatar
Yep 11 bolt; replace the tubes/o rings
George
Old 04-06-2021, 08:02 AM
tempest1964's Avatar
Just do what I do Charlie. After I run out of fingers, I go to my piggies….
Old 04-06-2021, 03:55 PM
I might even be beyond the piggies now.. It's been a while since I've bought stuff in the US. 50 dollars to ship the tubes and a new divider plate to NL ughh.
Hopefully it will give me some peace of mind whe.n I get to drive this car..
1968 - Pontiac GTO
Old 05-06-2021, 10:44 AM
HWYSTR455's Avatar
HWYSTR455 HWYSTR455 is online now
They make stainless plates and tubes now.
