Old 04-11-2021, 09:02 PM
jarretts70 jarretts70 is offline
Default Master cylinder for 4 wheel discs
I'm doing a rear disc swap on my 1970 GTO, using parts from a late 90's Blazer. This setup is pretty similar to the LS1 F-body brakes, with the "drum in hat" parking brake setup.
For now the front brakes are the stock discs, but these may also get upgraded to the LS1 fronts.
I installed an adjustable proportioning valve to the rear brakes.
I plan to run a stock 11" booster (fairly mild 455, should have plenty of vacuum).
Not sure the best choice of master cylinder. I would like to keep something that looks somewhat stock (no polished Wilwood or Chinese knockoffs...). My thoughts are c3 Corvette or 1979 WS6 Trans Am. I was leaning toward the T/A part; I figure my brake setup is comparable to a T/A, as is vehicle weight. Both masters are 1 1/8" bore; the Corvette uses two equal-sized reservoirs, while the T/A uses different size reservoirs like a disc/drum car. I'm not sure why, can anyone explain the reason & which master would be a better choice?
It's not exactly a hardcore track car or pro-touring thing, but it's being setup to handle & hopefully stop a lot better than 1970....
Old 04-12-2021, 05:28 PM
gtospieg gtospieg is offline
The size of the bore you need in your master depends on whether you are doing manual or power....1 1/8" is for power...1" or even 15/16" for manual.
Old 04-14-2021, 08:47 AM
MNBob MNBob is offline
You are really going to like those Blazer rear disks! They were a definite step up in performance from my factory rear disks. Plus the parking brake works really well.
I used an 81 TA master and booster with my stock front disks. This has worked perfectly. The 79-81 dual diaphragm boosters are some of the best ever from GM and provide more clearance for valve covers. The 81 master is aluminum and weighs 1.6 pounds versus the 9 pound 79. The 81 master must be used with an 81 booster because the part that fits in the booster is larger.
Engine Left
1979 TATA Extreme TKO .64
Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry
Old 04-14-2021, 11:50 PM
Hi MNBob, thanks for the feedback! I like the looks of your setup & engine bay in general.
