Old 09-03-2024, 12:53 AM
w72 w72 is offline
Default L.E.D. upgrade, specifically tail lamps
Has anyone found L.E.D. units that look like they ought to, but with increased brightness? Not very fond of the looks of the replacements that have a ton of elements arrayed on a circuit board, but would like better daytime visibility of brake lights and turn signals.
Old 09-03-2024, 09:24 AM
mrennie's Avatar
mrennie mrennie is offline
I used the Sylvania 1157 LED bulbs for my taillights. They are high quality and much different than many of the other ones on Amazon.They are only a bit brighter than a stock bulb but the instant on might get a bit more attention. Make sure you buy the red LEDs for taillights.
I also installed an aftermarket flasher that requires a connection to ground, which ensures a consistent flash rate regardless of load or bulb type.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 09-03-2024, 11:57 AM
I did the RAMC series I unit...it has a switch to make them work like stock
Thread Tools
Display Modes
