Threaded plug size
My machinist installed the threaded plugs that come with the Edelbrock heads into both heads for the Dyno. I don’t have an Allen wrench big enough to fit it and it’s HUGE anyone know what size it is so I can just go buy the right size bit instead of buying a full set of oversized Allen wrenches. My machinist is on a race tour till Wednesday and I am trying to get some stuff done.
Just measure between opposing flats. That's the size.
'65 Tempest 467 3650# 11.30@120.31 |
Depending on how huge, try finding a hex head bolt that will sit snugly into the plug. If you can, add a double nut locked together on the bolt and back it out with a socket.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
Mine were 9/16ths. Stick a 3/8 bolt head in it to be sure.
Nice and resourceful!👍
Clay |
Yup,I do that.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
