Old 03-02-2021, 08:43 PM
BigBrian442 BigBrian442 is offline
Lights out 12 was the first outing with the Pro Line engine... No testing before the event. Exceeded his best with the Pontiac on the 4th pass. Jamie Miller tunes for him... tuned the Pontiac combo also...
John,
I understand that. Not sure if they have ever had a handle on the 60 foot times. Pontiac ran a best of 3.949 in the low / mid 19x's MPH. I do not know if it was first time out with Pro Line engine. The one run I can find is 3.914 @ 203.7 MPH.
Stan
  #42
Old 03-02-2021, 09:33 PM
cgeise's Avatar
cgeise cgeise is offline
the 60ft times listed seem slow -- while most turbo cars are not great leavers Mine was quicker than that with a lot less hp , so it seems they need to do some chassis tuning
  #43
Old 03-02-2021, 10:41 PM
JSPONT's Avatar
JSPONT JSPONT is offline
He is putting the Warp motor in his other GTO, from what I read on FB. Break a Pontiac in that class, you go home. The way he went is the way all the fast guys in that class have, parts are not an issue.
  #44
Old 03-03-2021, 04:29 AM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
what size tire were you running?
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
  #45
Old 03-03-2021, 02:26 PM
cgeise's Avatar
due to limitation on body clearance it was on the smaller size -- 32s If I remember right
  #46
Old 03-03-2021, 11:32 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Default Youmans went to proline
Originally Posted by GTOGEORGE View Post
Are you sure, or are you just guessing?
I thought the body was a factory steel just tweeked in a few areas.
GTO George
I am not guessing. It is all aftermarket panels...you can ask Tommy Youman yourself.
1969 GTO, 3370 lbs, 10.5” tire...
07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads
