70 gto rear lower door panel
The plastic panel has a piece of metal screwed to it that runs up to the rear package tray. I put the screws in through the metal sideways and goes through the vinyl door panel. The top of the metal rests against the rear bulkhead. Question is does the top of the metal just rest against the bulkhead or does it attach somehow. Seems to be a little floppy to me and the factory would of attached it somehow but I don't see any holes that it would.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
Scott, no screws from the metal filler towards the rear. Just the 2 going thru the door panel on the side, and the 2 at the bottom to the plastic arm rest.
Jason |
What Jason said...be careful not to crack the plastic side panel when installing (or removing).
1970 GTO (Granada Gold) - 400 / TH400 |
Thanks guys,,,thats what I was looking for. Just looks like the top should be hooked to something.
