I believe he mentioned on FB putting the Warp6 motor into his 64 GTO.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
The Following 2 Users Say Thank You to Hooter For This Useful Post: | ||
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
Stan
The new engine is being run by several people and has parts availability. Not a nitch engine that he is doing all the r and d on. I dont blame him. Hope he keeps playing with the warp engine to.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
3.90’s would put you in the bottom half of the field in a 32 car field. It is a DNQ in a 16 car field.
Palbykins Pro Mod/ Big Chief's 70 Body shell (steel roof) actually came from a location out west. It started as a Pontiac built on a assembly line.
Agree the Youman car is all aftermarket parts. Now even the engine is not Pontiac based. Tom V.
I thought the body was a factory steel just tweeked in a few areas. GTO George |
IMO, I think with the right car, right Pontiac engine and right tuner, bottom 3.80’s to 3.80 flat would not be out of the question in pro 275 with a boosted Pontiac combo.
Exactly.
Can not wait for both of Steve Dales cars to get out on a track. |
Lol... of course he did... love the little Pontiac but like I and many others said, it can't swim in the ocean...
Glad to see he got away from kre's money pit.. |
Possibly.... its a stretch that few to none are willing to risk.. I know if I had the budget to rum 275pro, it wouldn't be strained on Pontiac parts.. ROI is key at that level..
This must make gto george sad...😢
I don't know if Tommy's Pontiac engine was maxed out (boost) or not. But the Pontiac made 3350 HP on a hub dyno which should be close to 4000 HP @ the crank. So what does a new Pro Line engine make?
Stan
Doesn’t matter what the plr motor makes. It’s what can the tire hold. As crazy as it might sound, it is harder to slow a fast motor down then it is To run a slower motor wide open.
There was a time when the common wisdom was that anything over 700 hp required a racer to abandon the Pontiac and go BBC. The people that were willing to work harder and spend $$ proved that the bar can be moved.
FWIW, Eric
The Following User Says Thank You to Elarson For This Useful Post: | ||
#38
I understand that. Not sure if they have ever had a handle on the 60 foot times. Pontiac ran a best of 3.949 in the low / mid 19x's MPH. I do not know if it was first time out with Pro Line engine. The one run I can find is 3.914 @ 203.7 MPH. Stan
#39
Are they allowed TC in 275pro?
#40
He had it on a hub a second time and posted a video of it making over 3600...
