Really allows me to get in and out of tight places. We've got about a 50' meandering sidewalk that is 42" wide from our driveway to our front porch (where it widens out to 7' wide. I can turn around by the front porch so I don't have to attempt to back out for 50'... Unless the snow is wet, it'll throw it 35-40 feet. |
Honda
Our Kansas snow mover. electric actuated.
Warn plow
What Warn model did you purchase?
“A veteran - wether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the (‘United States of America’, for an amount of ‘ up to and including their life.’” Unknown |
WARN
I ordered it all thru quadratech, a jeep parts supplier. you have to order items separate. mounting kit, actuator, blade. I don't recall the part numbers but you will find it at quadratech. I may have ordered just the warn blade elsewhere can't recall. the mounting kit is great, 2 quick connect pins and its on and off. right in the front, easy access.
some kits require underbelly lay on the ground off and on. that would be a bummer! the underbelly kits are cheaper but be much more a hassel. and you lose some ground clearance with that type as well as blocked maintenance access. get what you pay for. well worth it I use it to take care of my gravel driveway in summer, move any other loose dirt etc etc. not my video, hes got a cable winch. get the electric actuator and strap. better. https://www.youtube.com/watch?v=mrVoZ9P0eXM Last edited by JUDGE3; 02-23-2021 at 02:30 PM. |
After the last few weeks of record cold, & a week ago, a foot of snow, am planning a small addition to my building. Looked into radiant heat flooring before we poured the slab 4 years ago. At the time it seemed unnecessary & at right under 2900 sq ft, radiant heat was a no go. By this Fall, hope to have the tubing installed & the slab poured for 13 x 26 ft addition. Small clean room/paint booth being the goal.
I'm also glad I included a urinal- much nicer than out in the cold behind a tree.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
The more room the better is what i always say
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon! |
Enjoy the addition before it starts shrinking! I added 22x24 onto the back of my garage almost 20 years ago. Best thing I've done to the house and being a remodeling contractor (retired now) I have done a lot of remodeling here. A word of warning, the extra space works against the argument that "I'd buy that car but I don't know where I'd keep it". I used to have the entire additional space for larger cabinet projects and other work plus used it for a dining room for Thanksgiving and other gatherings. Now most of my projects, although smaller now, have been pushed into one corner because two cars now call the area home.
I separated the front and back of the garage with a 16' overhead door so I could heat just the back. That worked out well at first but now the door stays open and the whole area is heated. Have fun!
1969 Firebird 350 convertible, t-5, Carousel Red 2008 Solstice GXP 5speed manual, Sly 2008 Grand Prix, Ink Slate, Winter daily driver 2009 G8, Switchblade Silver, summer daily driver |
