Old 08-21-2012, 10:11 PM
goatless's Avatar
goatless goatless is offline
Originally Posted by Steve Hoog View Post
Well technically I would hold the car still a few more seconds into a tire warm up before rolling up.
Yeah, but those were my tires on the car!
1966 GTO
Old 08-22-2012, 08:22 AM
You could add a stop at the end of the 3rd gear to keep it from going into neutral.
(at least not as easy)
Old 08-22-2012, 08:39 AM
pggto's Avatar
pggto pggto is offline
Yes, there are three bent tabs. I think it will be far easier just to Mig or Tig if needed little chuncks and grind and polish to the T. The bent tabs wouldn't be impossible after cutting the main piece in the CNC but it sure complicates things.
Chris, I need one more plate to make one. Can you either send me the plate or your spare column?
Do you know how much force those tabs see? Maybe they could be replaced with a dowl pin in the correct location?
Old 08-22-2012, 09:38 AM
Steve Hoog's Avatar
Steve Hoog Steve Hoog is offline
formerly Steved400
Send a message via Yahoo to Steve Hoog
A dowel could work; I'm not even sure if the stops are terribley important. One is actually a guide and not a stop.
If Chris will send me his column I can get a better idea of how we could CNC one with dowels for example and make a more sophisticated piece with a third stop.
The Following User Says Thank You to Steve Hoog For This Useful Post:
Old 08-22-2012, 10:09 PM
The Boss's Avatar
The Boss The Boss is offline
I'll pull the spare one apart this weekend. If I have trouble (which I'm sure I will) I'll call you.
And go racin' in the street.
Old 08-22-2012, 10:31 PM
Steve Hoog's Avatar
formerly Steved400
Well I need one to try and figure out CNC, I'll check Ebay.
