Old 10-28-2021, 12:48 PM
wooftfd wooftfd is offline
Default Tri-power rebuild
I'm putting a tri-power on a 64 421, who do you guys recommend to rebuild the carbs?
Best, Trent
Old 10-28-2021, 01:20 PM
PY member Dick Boneske.
Old 10-28-2021, 03:01 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Dick is great.
Also Mike Wasson is great. 309-360-6385. www.pontiactripower.com
Dick Boneske. 920-450-1040
Old 10-28-2021, 03:04 PM
padgett's Avatar
padgett padgett is offline
Didn't the 64 421 tripower (B-Body) have a single element air cleaner and a low rise manifold ? Just checking memory.
Web Site
Old 10-28-2021, 03:25 PM
Kenth's Avatar
Kenth Kenth is offline
ALL 1964 Pontiac Tripower 389/421 engines uses the #9775088 intake.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-28-2021, 05:05 PM
tom s tom s is offline
64s were a one year deal,not the pancake design.Like a 65 with 61-64 water pattern.Tom
Old 10-28-2021, 05:21 PM
Angry
DAT was not the original question!
Old 10-28-2021, 05:53 PM
You guys are the best!!!
Old 10-28-2021, 06:25 PM
Even though Mike does a nice job, Dick B has repopped the correct 64 Mechanical Linkage for the 64 Tri-Power, (GTO and Big Car) systems (all of the pieces) and it is a fine piece of work.
Old 10-28-2021, 08:00 PM
I sent him a PM...
Old 10-28-2021, 10:34 PM
1_Wild_Cat's Avatar
Not that Mr. Boneske needs another reference but...I have got parts from him and spoke with him on the phone. He is a class act.
Old 10-29-2021, 09:24 PM
U47 U47 is offline
You read my mind. I was going to ask that!
Old 11-01-2021, 04:13 AM
Any objections to tackling the job yourself. I can send you more info. then you know what to do with. I spent the last 8 years building my 1979 Pontiac Firebird TA and 1966 Tri-Power system along with my roommate. Today, in one day we disassembled them, cleaned them in solution, washed them and assembled them and am waiting for Eastwood to send the Paint products to complete the job. Understand, this I am self-taught and I learned it all on line. The system is simple and I found everything you want to do the job yourself. Let me Know. I have text and photos and see the "Old car Manual project" it has all the Rochester 2bbl 2GC + 2GV info. just to start with.
http://oldcarmanualproject.com/ Go to Site Index first, Carburetor Manuals in e-book (pdf) format, Rochester 2-Jet Carburetor Manual.
updated February 22, 2003, Note: This date on the page, if you don't see this date beware of a copy page made to divert you to another site. In the past I got caught up with Ransom- ware, same page different date. What they did was to make an exact copy of this page but the date was off. I only realized it when it was too late. They tried to extort money from me to release my own photos on my computer. Also, it is a good idea to run the site through your anti-virus to scan it. Good luck, I have more on my computer if you want. I found that going through the Forums helped me. As I said I can save you time if you ask, I will post what I think you need. Mike out. P.S. This is not a job to be afraid of, if I can do it so can you. Also, I just tried the site I am sending you to and it works well, just follow my instructions to the letter. Keep in mind even if you elect to send them out, you should learn about the system, so you can maintain them.
Old 11-01-2021, 07:07 PM
"THE OLD CAR MANUAL PROJECT" Has Tri-Power Rochester Carb. rebuild Information for you to read and a lot more to enjoy.
LINK: I FOUND A SAFE WAY TO VIEW THE CARB. FILE HERE!
http://www.oldcarmanualproject.com/m...ch1973__2G.htm
