Exactly. Which is why I called them touched (or messed with).
So long, farewell. |
Shield
I read that on py that's why I asked about baffles. Are baffles considered shields? Im.still learning this stuff and trying to help other members
Baffles are the long piece that covers all the springs.
The shields are the things that cover one spring and held by the spring retainer.
The Following User Says Thank You to johnta1 For This Useful Post: | ||
This all stems from (iirc) some 1969 RAIII engines being built with the 'L78' #62 heads; But I believe that was only one engine code. I have asserted before that PMD seemed to do engines in two year cycles - even though there may have been yearly casting number revision changes ect, engines for any given year will follow a pattern from one other year... 1969/1970, 1971/1972, 1973/1974, 1975/1976, 1977/1978 For 1970, you see the same stuff happening in 1969. During the 1969 model year the 744 cam was phased out - the presence of that cam and the singular example of a Ram Air (III) having the 'L78' heads are the key differences between 1970 & 1969. As mentioned, the engine code is key here; Just like in 1969, the "hot ticket" was the 400-4bbl engines installed in the Tempest/Lemans & Firebird - when equipped with a manual transmission; For 1970, that meant these cars got the better #12 heads - which is why the "RAIII" head casting was used on WT engines for 1970. BUT!! This WT engine thing is the exact opposite of what is being discussed; The 1970 YZ & WS engines all recieved #12 heads. Anyone who suggests otherwise, is either guessing, or citing a vehicle that they do not have air-tight history on. Bad information spreads, and if someone is putting together a RAIII engine, the #13 heads can be had much cheaper than #12 heads - those heads were built in much greater numbers; For someone to believe that the wrong head is accepted as being correct on an engine they are putting together for a car they are building is often too convenient to pass up on...
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 10-05-2023 at 12:49 PM. |
The Following 2 Users Say Thank You to unruhjonny For This Useful Post: | ||
