Old 01-29-2023, 06:43 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default distributor question
My car was born 2nd week of Dec. 1964. 65 GTO. Could this distributor be correct for my car. The date code on it is 4 D 13. The part # is 1111052.
ID:	606264   Click image for larger version
ID:	606265   Click image for larger version
ID:	606266   Click image for larger version
Old 01-29-2023, 08:57 AM
johnta1 johnta1 is online now
That date code is April 13 1964.
Your distributor number should be 1111078 I think.
Old 01-29-2023, 06:16 PM
Kenth's Avatar
Kenth Kenth is offline
1965 GTO´s should have a #1111054 points distributor.
#1111052 is for 1964 326 cui and 421 cui V8´s.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-29-2023, 06:55 PM
From Service Craftsman News issue 6 - 1964 (pg 67)
This would have come out before Jan 1st 1965.
(not sure of actual date they come out)
Also doesn't say for GTO or not GTO.
Old 01-29-2023, 07:13 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Maybe your 65 started with TI that went bad. That could be a normal conversion piece. My 64 has the born with the 052 unit.
"Bill"!
Old 01-30-2023, 05:30 AM
Kenth's Avatar
This info would be for Pontiac - Standard Cars (B-body).
Pontiac Tri-Power and GTO engines still used the 1111054 distributor.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 01-30-2023, 07:24 AM
dhcarguy's Avatar
OK, thanks guys. I guess from the info., it was not original to my car.
I will probably sell it later if the one in my car is OK once I pull it out and get it calibrated to my cars engine. ( I have never pulled it out since I've owned my car.) 20 years.
Dave
Old 01-31-2023, 08:14 PM
bill ryder's Avatar
Sorry for the bad info. My born with is 1111054. NOT 052. My daughter says I have "SOMETIMERS"! I say it's CSR. Sorry for the error!!!!
"Bill"!
Old 01-31-2023, 10:48 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 054 Distributor
Here is an old 1965 Sun Electric Corporation sheet showing the 1111054 distributor.
They listed the engine codes and carburation incorrectly on this sheet.
The 1111054 was also used on the 1966 GTO with standard ignition.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 02-01-2023, 05:14 AM
Kenth's Avatar
1966 4-barrel GTO´s uses the 1111078 distributor, Tri-Power GTO´s got the 1111054 distributor. There is also a 1966 2:nd production Tri-Power distributor #1111175.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
