#41
IIRC Langer made near 1000hp with a 370cfm Wenzler head many years back. These new 490cfm - 500cfm heads should blow those away if cfm is all that matters. Poke a big enough hole in any head and it will flow whatever you want it to flow
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#42
I think rod length also comes into play here as well
#44
Yeah, plus the resonance frequencies of the rod shape and density of material? I try to tune them with the valve springs also. Helps controlling the valve past 8K.
#45
================================================== == Beginning to figure that Langer's statement on flow below .550" lift must have much to do with the type of fuel delivery & inhale tract wet-flow capability. Afterall a 330CFM ave flow that made a fuel pee puddle on the slug top would combust poorly. All the while we focus on flow numbers so we can say... "it's in the hole. It's in the hole! The cinderella kid has done it.." Yea, the age-old HP challenge has been to get&maintain a fuel-air suspension on the upstroke for good ignition. |
#46
Most of the racers that have switched from the 300 / 330 CFM heads to my 350 CFM CNC E-heads have picked between .50 to .75 ET and 6 to 8 MPH. Calvin Hill Hill Performance / Mondello Tech Center 708-250-7420 |
#47
I use averages from .100" to .900" lift. The averages would be higher if I used .300" to 1.000" lift.
#48
http://www.thebmfstore.com/ProductDe...ductCode=10405 Calvin Hill Hill Performance / Mondello Tech Center 708-250-7420 |
#49
http://en.wikipedia.org/wiki/Pot_cal...e_kettle_black Maybe I can sell this "upgrade"? Call now and mention this thread and I will give a 100$ discount. |
#50
Runner Up Q16 Norwalk 2013! |
#51
Just pull'n your chain.
#52
How do you know you got 360 cfm without checking it on a flow bench? Just saying!
#53
What Planet did you get that idea...Blacktopr has a high depression, wet-flow capable flowbench.
