69 Firebird Steering Linkage
I recently purchased a complete steering linkage for my 69 Bird from a forum member which includes the curved pitman arm idle arm assembly. Pic of assembly attached.
I already have the curved pitman arm on my car which is factory 400 PS car. When comparing the idle arm assembly, the one on my car (unknown if original) is a different shape like this: https://www.googleadservices.com/pag...gQIEhBD&adurl= The one I just bought looks like this: https://www.googleadservices.com/pag...gQIEhBY&adurl= Also - the one on my car, like the first link appears to be one-piece assembly versus the second link which shows bracket and idle arm as separate pieces. A quick unassembled match up does not appear to pose any issues but I won't know till it's installed. Does someone here know which one is correct and if the one I bought will work.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 03-11-2021 at 09:19 AM. |
The one on the table looks right. Here's my original one.
Cholesterol Bad Adrenaline Good Do it till your eyes bug out! |
That’s a pitman arm - What does your idle arm look like?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
Oops my bad, I thought you wanted a pic of the Pitman Arm. How's this one? Hope it helps.
Cholesterol Bad Adrenaline Good Do it till your eyes bug out! Last edited by Sport69; 03-12-2021 at 06:21 PM. |
Are you referring to the bend not being there in the -Idler- arm you got?
Yes - apologies for the lack of clarity in post
More pics if it helps.
Thanks- the pic you posted in post #6 looks like your idle arm is also straight. Is this replacement or original?
As far as I know it's original. I've heard that it's hard to find the correct ones.
