Old 05-07-2022, 08:11 PM
64speed's Avatar
64speed 64speed is offline
Default Starter grinds when hot
The starter on my car works great on the first start but after the engine warms up it either grinds like hell or wont even start it grinds so bad I give up. It just started doing it so I went and had a new pinion put on because it had been chewed up so bad and they said it tested fine and that it was just the pinion chewed up. I put it on and it started up great cold. Once it warmed up it started doing it again. I think it tested good because of course they only tested it cold
Old 05-07-2022, 08:19 PM
F ROCK's Avatar
F ROCK F ROCK is offline
I had a Hays flywheel. Ring gear was somehow too large?
I couldnt shim it enough! It ate my mini starter.
Google search revealed others had the same problem w/ the Hays.
I bought another flywheel at autozone.
Noticeably smaller than the Hays.
No problems at all.
Learned my lesson about Hot rod parts.
The Following 2 Users Say Thank You to F ROCK For This Useful Post:
Old 05-08-2022, 01:49 AM
NeighborsComplaint's Avatar
Could be heat soak from the headers and the solenoid isn't pushing the pinion full travel.
Triple Black 1971 GTO
Old 05-08-2022, 03:42 AM
64speed's Avatar
What are you guys running for starters? This is a summit mini? I am looking at Robbmc but $$$$ and I’m hemorrhaging money now.
Old 05-08-2022, 09:47 AM
AG's Avatar
AG AG is offline
Did you check pinion to flywheel engagement by pulling the starter pinion onto the flywheel and measuring the clearance? Sounds like engagement is too deep, check the marks on the pinion gear to gauge how deep the contact is.
Old 05-08-2022, 10:41 AM
John Milner's Avatar
I had a summit mini starter that would grind until I removed the shim I was using. I’ve found that no shims work the best on stick shift cars.
Old 05-08-2022, 11:46 AM
grivera's Avatar
grivera grivera is offline
I’m using an IMI mini with zero gauge battery cables and Ford solenoid- no starting issues.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 05-08-2022, 11:56 AM
stellar stellar is online now
Check the teeth on your flywheel. Go completley around.
Old 05-08-2022, 12:20 PM
Ford solenoid is the best solution.
I put a Powermaster mini-starter on mine and couldn't clock it to any useful position. My battery connection post is about 1/4" from a header tube. My stock GM starter had more clearance to the headers and with the Ford solenoid, I never had any starting problems but just didn't like the way the solenoid looked hanging on the fender well. I convinced myself the Powermaster Mini was the solution but it heat soaked too. I went back to the Ford solenoid.
Old 05-08-2022, 06:47 PM
64speed's Avatar
Well I will find out tomorrow if I’m changing flywheels or not
Old 05-08-2022, 09:08 PM
misterp266's Avatar
FYI, Robbmc starters cannot use a Ford solenoid. Read the instructions first.
I use one with my Tilton Super Starter, works great every time.
" Darksiders Rule "
Old 05-08-2022, 09:31 PM
64speed's Avatar
I’m afraid I’m gonna end up needing a flywheel. I seriously have no idea why but it just started grinding like hell and no matter how I shimmed it it just got worse and worse. Second starter just ravished the flywheel. I am hoping a regular full-size ac Delco starter can save it but I seriously doubt it. If I have to put a flywheel on it she’s dead in the garage cause summer vacation and daughters band stuff is on the horizon and I’m broke.
Old 05-08-2022, 09:43 PM
moneypit's Avatar
moneypit moneypit is offline
I run a Robbmc on my 37. Last time I had an issue I sent the starter back thinking the solenoid was bad. Robbmc replaced the solenoid with a lightly used one and sent the old one back as well telling me that it was fine. At their suggestion I put a ford solenoid on the firewall and it's been working great.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
77 Grand Prix base model, 350 pontiac
97 F250 7.3 turbo diesel
85 CJ7 Laredo
65 Impala SS 396, 4 spd, A/C.
Old 05-08-2022, 10:28 PM
242177P's Avatar
242177P 242177P is offline
Originally Posted by 64speed View Post
If I have to put a flywheel on it ...
And IIRC, that transmission was shoehorned into place. When it rains, it pours.
Old 05-09-2022, 07:56 AM
64speed's Avatar
It was put in the first time with the front end off and there was no way to get it out without pulling the motor. It was the upper right bolt that was gonna prevent it. A BFH cured it while it was out but it’s still gonna suck
Old 05-09-2022, 08:36 AM
David,
What brand of flywheel are you using, that you can't change the ring gear on?
Clay
Old 05-09-2022, 11:53 AM
ID67goat's Avatar
ID67goat ID67goat is offline
Originally Posted by "QUICK-SILVER" View Post
David,
Clay
X2…Was able to replace the ring gear on my Hays flywheel.
Old 05-09-2022, 04:03 PM
67Fbird's Avatar
67Fbird 67Fbird is offline
cheaper yes but the time in pulling the trany out might be his killer.
Old 05-09-2022, 04:43 PM
With Flywheels, usually if they aren't too worn or badly chewed, I just flip the ring gear around and keep using it.
If it's so bad that you can't do that, a ring gear replacement isn't all that expensive to do.
https://youtu.be/XqEydRRRwqE
Old 05-09-2022, 04:45 PM
On Pontiacs, if I have to have a mini, it's a RobbMC with the pinion support. I don't care for the other aftermarket stuff out there. But 9 times out of 10 the stock starters work just fine for me.
