Old 11-08-2021, 10:02 AM
Jay S's Avatar
Jay S Jay S is offline
If the dog bone can’t be pried up with the plate on top of it and fitted to the block, that part sounds good. But from what I see in the photo’s the dog bone needs to be centered better. When the dog bone is up against on lifter it lets the other lifter rotate a lot. See the photos below.
If the plate is actually supporting the dog bone on the inside and the block is supporting the dog bone on the other side, and the dog bone can’t be pried up at all on the block side then that is quite a bit better than using the modified Ford spider to hold down the Ford dog bone (which are really to short) in a Pontiac. I am afraid with the dog bone pushed up against one lifter the dog bone is not engaged far enough into the adjacent lifter, which is allowing the lifter to rotate to much, it will be pretty hard on the axle bearings with that much rotation.
When a dog bone fails one ear will usually break off. With the dog bone pushed all the way to one side the forces on the dog bone ears increase a bunch, at least they would have with the spider assembly. The way you have the spiders sandwiched in between the plate and the block it might support the dog bone ears better, and a ear would only break after an axle failure. IMHO the dog bone are really to short, if you could find away to keep them centered I think you would have more success. I commend you on your efforts. It sounds like it will run like that, how long it will run before something fails, that is the million dollar question.
ID:	577218   Click image for larger version
  #142
Old 11-08-2021, 10:23 AM
Jay S's Avatar
Originally Posted by 78w72 View Post
im a little late to all of this, so the plate system from randy isnt working too well for you guys that are trying it? the video he posted looked like it was a tried & tested set up & seemed to work pretty good... is he MIA now??
also what is the mention of the rhodes lifters being used, i thought this plate system was specifically for the sealed power type roller lifters. just curious & sorry if i missed some details in the 7 pages of this thread.
We tracked down that Rhoads modifies speed pro 2148 lifters and converts them to Vpro and Vmax.
It does appear the from 80TA’s efforts the small base circle cams that are pushing the base circle limitations of the 2148 lifter are problematic with the plate, on his combo the plate is a little to wide. I found some blocks that the top oil hole on 2148s gets exposed at max lift on some Pontiac ground 1.88-1.89 cam core too, but it is dependent on how the block is cast, later blocks appear less to have slightly shorter lifter boss’s.
Hot rodding most everyone likes to push the limits of stuff, JMHO but the lift range the plate system and 2148 lifter will work best on should have started life as a small block 1.86 ish cam core (not bigger the 1.889 Pontiac) using lobe lifts .31-.35 looks to me like good combos with the plate system and the 2148 lifter with most any Pontiac block.
  #143
Old 11-08-2021, 06:59 PM
69 Limelight 69 Limelight is offline
Default New Hydraulic Roller Lifter Option - Arrow Engineering/Goatzilla Racing
What I want to know is where is Randy Repp now? He was all over this forum when he was getting this system kup and ready for sale. Now we have a customer who bought it with full confidence that it would work and Repp's curiously absent. Looks like he would be helping to get problem worked out if he wanted to sell more of these systems. I, for one, was really interested for next build but I'm out now. I'll stick with link bar. Haven't had a problem so far.
Since, to my knowledge, he hasn't responded to calls or e mails I think I would have removed all components, boxed them up and keep trying to get in contact and demand a refund. Now that they've been ground on kind of screwed.
Very poor customer service. Just my 2 cents.
The Following User Says Thank You to 69 Limelight For This Useful Post:
  #144
Old 11-08-2021, 08:32 PM
ponjohn's Avatar
ponjohn ponjohn is online now
Has anyone tried the Ford Spider?
  #145
Old 11-08-2021, 10:48 PM
grivera's Avatar
grivera grivera is offline
Post 128:
http://forums.maxperformanceinc.com/...&postcount=128
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
  #146
Old 11-09-2021, 03:57 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
Default New Arrow Injuneering Roller Lifter Guide Plate Instructional Video
https://www.facebook.com/PontiacArro...98824972247035
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
  #147
Old 11-09-2021, 04:20 PM
Default AIRLGPS & Valley Pan Clearance
If you want to run the factory valley pan you'll need to remove the two bumps on the lower side where the studs go through or simply run the sheet metal aluminum style valley pan.
Randy Repp
  #148
Old 11-09-2021, 10:44 PM
1980 TA 1980 TA is offline
The parts from Randy are un modified at this point. Its the dog bones that I have modified to get them to fit my block.
I've got the dog bones fitted now so that they are centered between the pair of lifters. There is no way that the dog bones can rise off the top of the lifter bores with the plate in place. With the Ford Spider I could see how the dog bone could ride up and or rock between the lifters. The bottoms of my dog bones are under cut and the top of the lifter has about .005 clearance between the top of the lifter flats and the bottom of the dog bone.
I'll try to get some better pics out as soon as I can showing what has been done.
I've got a PM to Randy asking for a phone call so hopefully we can sort out why I have no contact between the plate and the lifter, when the lifter is at the bottom of its travel.
  #149
Old 11-09-2021, 11:25 PM
Here's a pic of the dog bones after grinding.
I had to grind the block side down to where none of the vertical element was left.
ID:	577346   Click image for larger version
  #150
Old 11-10-2021, 12:47 AM
tom s tom s is offline
The one thing I have learned from this thread is I’m going to stay with the tried and true 70 years link bars.Good luck with your venture.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
  #151
Old 11-10-2021, 10:02 AM
ID67goat's Avatar
ID67goat ID67goat is offline
X2!
Both the dog bones and plate system look dangerous to me. I keep wondering how either of these would hold up to an over-rev or where you reach the point that the valve train becomes unstable (valve float).
I used to play with 5.0 mustangs and the dog bone system worked fine on those cars, but grinding them that much to fit, seems like a good way to have one break on you.
  #152
Old 11-10-2021, 12:44 PM
NeighborsComplaint's Avatar
I don't understand what you're trying to accomplish here. The dog bones maintain the lifter alignment and duplicate what the plate is meant to accomplish. You still have to fabricate a "spider" to keep the lifters from flinging the dogbones off.
Triple Black 1971 GTO
  #153
Old 11-10-2021, 01:13 PM
grivera's Avatar
He used the plate to pinch the dog bones between the block and plate.
Will Rivera
  #154
Old 11-10-2021, 05:19 PM
I'm at the point that I'm not happy with either the plate or the dog bones. I spent time last night trying to adjust the plate one last time, starting from scratch and could not get it to contact the outermost lifters (1 and 2 exhaust were the worst, with 7 exhaust not far behind. For some reason 8 exhaust would catch the plate but it wasn't by much).
I re fit the dog bones and the modified Ford spider was not going to work. I tried the plate holding the dog bones in place and when I got it where I might have thought it was a good idea to fire it up, I tried wiggling the 1,2,7, and 8 dog bones catching them with a pick and trying to move them fore and aft and up and down. They all had a fair amount of fore and aft movement and up and down movement. If I adjusted the plate any tighter, I had too much drag on the inner 8 lifters.
As soon as I get some time to talk with Butler on the phone, I'll be ordering some link style lifters.
  #155
Old 11-10-2021, 05:29 PM
slowbird's Avatar
slowbird slowbird is offline
Can you grind the plate so it won't contact the lifters, then crank it down to hold the dog bones? Just a thought
  #156
Old 11-10-2021, 06:02 PM
Murf Murf is online now
I’ve been thinking about this deal. Do you think taking a little off the bottom of the lower “stand offs” would allow the plate to drop farther down & catch the lifters better? Then you might have to clearance the plate for the ones that are fitting correctly. Just a thought.
Murf
  #157
Old 11-10-2021, 06:18 PM
Jay S's Avatar
If I read it correct Murf understands what it will take to make the plate work, except I don’t think it requires any machining to drop the plate at the center stand adjusters, the lifter hitting is what is holding up the plate, not the center hold downs. All it would take to make the plate work is to grind or file on the plate at the lifter or lifters that is to tight on maybe one or two lifters, then adjust the plate down accordingly. A couple lifters are not letting the plate drop enough. I mentioned it a few posts earlier, Randy’s videos have said the exact same thing.
If your not willing to grind on the plate, bale on these 2148s and get a link bars set up. Personally I would get these: https://butlerperformance.com/i-2445...tegory:1234800
  #158
Old 11-10-2021, 08:24 PM
The dog bones are intended to articulate as the lifters rise and fall via the radius ground on the underside rather than serve as a rigid guide. As the plate is raised above the level of the dogbones, it no longer provides any alignment and serves only to restrain the spiders which were never intended to be locked in place. This is looking like a boondoggle to me, but I'll butt out.
  #159
Old 11-10-2021, 08:51 PM
68hotbird 68hotbird is offline
Default mine has dog bones
my test mule motor with the sealed power lifter and dogbones and the ford spider have now been seriously abused for a few thousand miles and it is working awesome. I will be doing a coupe more soon.
The Following User Says Thank You to 68hotbird For This Useful Post:
  #160
Old 11-10-2021, 08:52 PM
my test mule motor with the sealed power lifter and dogbones and the ford spider have now been seriously abused for a few thousand miles and it is working awesome. I will be doing a couple more soon.
