Basic STOCK Piston Volume question
This is a STOCK Bore 400, with its Born with pistons. It is the earlier style of
Piston WITHOUT the top tapered edge you see on say a '76 400 that looks similar. So, What is the original CC of this Piston. ( we are NOT discussing its location at TDC) . Thanks for your exact info, or educated guesses.
6.7ccs.
The Following User Says Thank You to b-man For This Useful Post: | ||
Thanks! The recessed button had me thinking it could be more, but now I know, !
If that is a stock engine it’s never been machined can you measure how far down the piston is in the bore at top dead Center? I’d like to know
Build it Right Build it Once!!! Just another Engine Builder from the Northwest lol |
The Following 2 Users Say Thank You to Pontiac Derek For This Useful Post: | ||
Dereck, 389 and 400s should be .023” according to a factory chart and a 455 is said to be .013.
With factory machining tolerances on rod center to center, piston compression height , crankshaft stroke and deck height I would say that these factors could make for the .023” and .013” numbers being ,010” larger or even smaller. For example factory tolerance on the connecting rod center to center is said to be on there blue print 6.623” to 6.627. I don’t know what the tolerance would be for 421s and a 428.
I do stuff for reasons. Last edited by 25stevem; 02-16-2022 at 05:26 PM. |
The Following User Says Thank You to 25stevem For This Useful Post: | ||
Caliper says its less than .023, so I will verify.
Thank you I appreciate that
If the OP really wants to get focused more on what the CCs are then calculate what the volume of the big factory taper is on the top of the Bore to guide the rings in.
It looks to me like it's atleast.130" tall. The first part of the displacement formula would then be 4.125" x4.255" by my guess.
Opp's Sorry, that's where the ring travel stops.
Here is the evidence. Block and piston clean. Block has some dark between the broach marks, but its flat and level.
Perfect, thank you!!!
Close enough to dead on factory spec ( .023" ) for me!
In fact if you had not yet tapped the Bearing clearance out of it very well may be 100% dead on!
