Engine Harness and Tach Wiring
I need a new engine harness since my car came with a mangled one. I only find two options listed for 1966, with and without A/C .
My car has factory rally gauges, I thought this took a different harness ? and is my tach wire in the standard harness or do I need the tack wire harness as well ? |
I may have done wrong, but when I bought my new dash harness I chose the one for "factory gauges". I have yet to install it so I don't know about the tach connection yet. I'm thinking the engine harness I bought does have a Tach wire, but it too is not installed.
Wiring is all Greek to me so there is no telling what I will end up with.
Fort Worth/Dallas TX area 1966 GTO Fontaine Blue 389 CID Carter AFB Muncie 4 speed (orginally an automatic car) |
Back then, the engine, dash and tach harnesses were all separate.
I think the engine harness is the same except for the A/C. The tach harness is separate and the dash harness would be different depending on how the car is set up; i.e. automatic or manual, console or column shift and gauges or no gauges. I used M&H for all my wiring and it was all correct and just like factory.
http://www.wiringharness.com/
Remember no one is perfect. Everyone's butt has a crack in it! |
