Old 10-22-2021, 12:25 PM
cnc's Avatar
cnc cnc is offline
Default Looking for opinions 200 4R behind stock 350 Pontiac
So just wondering that once I get done with my combo I currently run....if I went back to the original 350 that was in the car. Would a stock rebuilt 200 4r survive without issue....
Guy around town rebuilds with converter for decent price ...he's a retired guy and former GM tech...looking for opinions/thoughts here for possible down the road changes.....thanks
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 10-22-2021, 12:37 PM
Formulabruce's Avatar
The Pontiac 355 ( yeah its Not a 350) has probably 310 Torque in '73.
That is a bit much for a stock rebuild of a 2004R.
You want a 10 vane pump and some quality clutches.
You want it built for a 1 wire hook up ( lock up solenoid) only so no need for a computer/controller.
Add a mild shift kit to above with a stock converter and you should be fine.
Can use a STOCK TH400 cross member, and stock Driveshaft from a th350, or 4 speed.
will need an adjustable TV cable and bracket for it at carb.
Finding a Converter "dust cover" with the DS mounted starter is a chore, but not really needed.
Ensure you use a transmission cooler, in addition to, or in place of the tank cooler in radiator.
Excellent and easy choice ..
Old 10-22-2021, 12:54 PM
moparcolt's Avatar
moparcolt moparcolt is offline
I had a stock one form a Grand National in my 67 firebird for years, if you dont beat it to hard it will be ok, as long as the TV cable is adjusted right.
it ha d a 467 stroker in it
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
Old 10-22-2021, 01:02 PM
besserspat besserspat is offline
Are you starting to consider making your car just a nice driver and enjoy as it is?
Im saying that because I have a very similar car ( 73 esprit that has a very nice running 350P and th350 with a 4 pinion Nodular diff from a 68 F bird.
Its an excellent driver, and I also happent to have a '87 GN 2004r transmission, and thought many times about swapping the 2004r in it.
But I have been building a complete drivetrain for the car for years and now its ready to go in the car . Its a 461 with SD performance ported Iron heads, a Jakes performance Th400 and continental 3200 converter with a built 30 spline 8.5 10 bolts with true trac and 3.08s.
Im sure i will have fun with the new drivetrain but that little 350P is very nice putting around town.
I also thought about putting a 400 with a 4 speed ,, but thats another story lol
As for the 2004r I have studied the questions extensively ( I even thought running a built 2004r behind the new 461 before I settled for the th400, because ill run a 200 shot), Any good transmission shop can make a 2004r can be simply rebuilt with decent parts and no fancy or expensise billet parts to cope with a healthy 350p daily driven. You need a good torque converter, lock up switch running vaccum or electrical switch, and pay lots of attention to the TV cable adjustment with the appropriate bracket.
The 2004r is a great transmission , I love the gear spread and simplicity of it.
Peter
Old 10-22-2021, 05:43 PM
cnc's Avatar
cnc cnc is offline
Hi Bruce ...I thought it was actually a Three fifty four....
I'm just looking at this a down the road adventure should I decide to do this...it would make the car way more road friendly and a little easier on the pocket book...
Old 10-22-2021, 05:51 PM
cnc's Avatar
cnc cnc is offline
Here's the ad ...I was gonna go chat with him just to see
https://www.kijiji.ca/v-transmission...ion/1514465675
Old 10-22-2021, 05:52 PM
cnc's Avatar
cnc cnc is offline
Peter
Yes maybe in a few years ....that might be in the future car was originally 350/350 so ,I have the driveshaft and cross memeber( l think) need trans converter and carbureter connections...
Old 10-22-2021, 05:54 PM
cnc's Avatar
cnc cnc is offline
What stall converter with my 342 gear ???? Again this would be just a cruiser probably headers and 4 barrel that's it...and back to the 354.....
Old 10-22-2021, 05:56 PM
cnc's Avatar
cnc cnc is offline
Peter
Peter is your 200 rebuilt already....
cnc's Avatar
cnc cnc is offline
If I do this down the road I want it as simple a swap as can be ....
Old 10-22-2021, 06:54 PM
turbo69bird's Avatar
My buddy is well known for his 200r4 rebuild he does pretty much all the GN guys transmissions who go fast. If your interested PM me you number and I’ll text you his info
960 HP @ 11 psi, 9.70 at 146.
The Following User Says Thank You to turbo69bird For This Useful Post:
Old 10-22-2021, 07:05 PM
ponjohn's Avatar
ponjohn ponjohn is offline
https://www.youtube.com/watch?v=FOlqQXY3Gac
Old 10-22-2021, 07:29 PM
ta man ta man is offline
You know its never simple..lol
Old 10-22-2021, 07:54 PM
Sirrotica's Avatar
Here's a table showing the torque rating, max GVW, torque convertor diameter, and length, of all stock GM transmissions, the 200-4r is 330 lb/ft according to this table. Probably adequate for a mild 350 P, not my first choice, but I'm not going to bore anyone with that, nor start an argument here.
This chart is good starting point for anyone contemplating an OD 4 speed for their car.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 10-22-2021, 07:56 PM
cnc's Avatar
cnc cnc is offline
How true…
Old 10-22-2021, 08:00 PM
I highly recommend the Bowtie Overdrives TV and Throttle Cable SYSTEMS
https://www.bowtieoverdrives.com/
Old information here:
Old 10-22-2021, 08:15 PM
I had a 200-4R behind a 462 in a Lemans - did just fine including track time. You will want at least 3.42's as carbs lug in OD at 60-70 mph.
Old 10-22-2021, 08:56 PM
This is relatively easy and a great way to be able to enjoy your car. All bolt in. I even have the back drive hooked up, and the shift point on Trans side
is in a different spot than a th350. I run a stage 3 with a mild shift kit behind a stock CR 72 455HO. Easily ruins a driveshaft, but not the transmission.
200 is THE best bolt in OD ratio at .67
My shifter mods came from "Shiftwerks" and I did use a bowtie overdrive cross member, BUT found my TH400cross member is a bolt in fit.
with a 3.42 10 bolt posi......Locked up in OD
ID:	575913   Click image for larger version
Old 10-22-2021, 09:00 PM
STOCK converter . Really want to send that Ice cream cone into the rear window glass and waste gas?
Old 10-22-2021, 09:08 PM
cnc's Avatar
cnc cnc is offline
Bruce u mean for the lock up converter operation with a brake switch or other means…can you elaborate or do you have a post here on the forum to read ….
Missed that STOCK converter in your original reply
