Old 10-22-2021, 09:09 PM
besserspat besserspat is offline
Originally Posted by cnc View Post
Peter is your 200 rebuilt already....
No, its from a virgin out of an original 87 Grand National that was getting a new Art Carr tranmission installed because the owner was bui;ding the car for maximum track effort.
I dont think I would sell it , I like to collect parts just in case. But Im sure a mild 350p with a th2004r and some gear would be very fun to drive around.
Peter
Old 10-22-2021, 09:10 PM
cnc's Avatar
cnc cnc is offline
STOCK converter . Really want to send that Ice cream cone into the rear window glass and waste gas?
Hahaha…….nope..
What is the stall of a stock converter for 200 trans ?????
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 10-22-2021, 09:27 PM
Formulabruce's Avatar
You want it built for a 1 wire hook up ( lock up solenoid) only so no need for a computer/controller
Bruce u mean for the lock up converter operation with a brake switch or other means…can you elaborate or do you have a post here on the forum to read ….
Missed that STOCK converter in your original reply
I hooked my 1 wire coming from the 4 pin connector on the trans ( lock up solenoid) to the th400 kick down switch wire.
The trans needs to be built so it shifts up hydraulically like a TH350, as you dont want a controller making your upshifts as you would need a Programmer like a 700 does.
A 1989 2004R from a GTA had a lock up in 3rd and 4th gear ( just a worthless fact, but needed at indy)
Old 10-27-2021, 04:33 PM
FHummel FHummel is offline
The 200-4R will stay in there with the 350. There were performance parts available for rebuilding those trans's back when I had one done about 2005, or so. I used one behind a very healthy 455 with 500lb ft of torque. Used a lockup convertor. This was in a 1961 Bonneville 2 dr hardtop. Wish I still had it.
FHummel
