Best Reproduction Shaker Seal
Got no response in 74-76 section and since their the same asking here
Who makes the best reproduction shaker seal Mine is not flexible / dry rotted it came with the shaker I purchased.
74 Formula 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.075 @ 112.70 12.092 @ 112.43 12.128 @ 111.71 |
I’d be hard pressed to believe that any of the repops arnt from the same source. So in reality they are all the same no matter who you buy it from. If your not looking for a perfect one I have many you can choose from at no cost
The Following 2 Users Say Thank You to Norwood For This Useful Post: | ||
Will contact you later today
It wouldn't be too hard to find something that fits and works better than squashed and dried out 50yr old rubber seal. It looks like this, not sure if early years were the same, ends up flat with a depressed rib in it. Norwood will have something that works.
Don't feel disheartened. I find the 74-76 years are dead in most forums, limited owners and limited advice, those that post don't even own one! Give or take a few good guys! Although, you only waited a few hours! NOS GM 527230 adhesive shaker seal Trans Am 2 by Aus78Formula, on Flickr Last edited by Aus78Formula; 11-12-2021 at 08:27 AM. |
Thanks Norwood a.k.a. Craig for the shaker seal
