Old 01-25-2023, 08:03 PM
sdbob sdbob is offline
Default 1967 Firebird with 4 spd Changing from automatic
My 67 was original 4spd. When I got the car the 4spd was missing. So I put a m40 in. Now I'm thinking go with a 4spd. I bought a 67 Firebird 4spd from Jim Mino. I bought a McLeod 11 inch pressure plate and disc years ago sitting in cold garage. I was going to use oem flywheel now I'm thinking better to go aftermarket. Which flywheel should I buy? Also throw out bearing? I need the clutch fork also? I have oem bellhousing and a Lakewood with blockplate. Also Lakewood clutch fork new. Any recommendations basically street car use. Thanks.
Old 01-25-2023, 10:37 PM
4dblnkldude's Avatar
Your gonna need a really long ball stud if you use the lake wood.
Old 01-25-2023, 10:54 PM
tom s tom s is online now
I would run the factory bell with all good stuff inside it.Tom
Old 01-26-2023, 08:56 AM
That's why I mentioned stock bellhousing,convenience. Thanks for advice. Now what brand flywheel? Name brand or Summit brand?
