Rag joint washers?
Took out 2 bolts in rag joint to get a couple inches of clearance for manifold bolt. In the process two small washers with grip perforations fell to ground and I don’t see where they go. Below includes pic of washers, remaining hardware and joint before disassembly.
Any idea where these washers go? |
They go over the bolts on the rubber before the steering flange goes on .
Thanks Chrisp. Just so I interpret correctly - can you look at this pic and tell me which location you mean? I suspect its one of those inner ones, 2 or 3 - but a picture always helps clarify. thanks for your help...
Here is a pic. The 1 with the tang acts as a ground strap .
