Old 02-21-2024, 08:46 PM
cnc's Avatar
cnc cnc is offline
Default computer help
so I have an older ASUS tower AMD A8-5500 APU with Radeon(tm) HD Graphics 3.20 GHz,4.00 GB (3.45 GB usable),64-bit operating system, x64-based processor with Windows 10 on it...the ram is one stick ASint DDRIII4gb-1600....I want to speed this up a bit if possible can i add another stick to this , or change out this one with 2 bigger ones ????….. there is another slot just like where this stick currently sits and what is compatable with this ...if we need a pic of the board i can get it i have no side cover on it at the moment....thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 02-21-2024, 09:51 PM
Wideone's Avatar
Wideone Wideone is offline
If you can identify the motherborad, you should be able to find it's memory specs on line. In general you should be able to add a matching stick with no problems. Before you get carried away, you need to know the max memory your boars supports. Boards have the id info imprinted on them. Good luck.
Old 02-21-2024, 10:16 PM
cnc's Avatar
cnc cnc is offline
Is it cm1435
Old 02-21-2024, 10:22 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Here is the spec sheet on your motherboard.
https://icecat.gr/rest/product-pdf?p...381695&lang=en
You can go up to 16GB with (2) 8GB modules.
Old 02-21-2024, 10:41 PM
cnc's Avatar
cnc cnc is offline
Hmm so I can get 2 ……8 GB sticks now I see there is BUFFERED and UNBUFFERED ram …which do I want…no idea what is in it….
Old 02-21-2024, 11:33 PM
srmmmm's Avatar
Non-ECC un-bufferred
Old 02-21-2024, 11:41 PM
cnc's Avatar
cnc cnc is offline
Lol what is non ecc...since it's oldd looking for something decent is crucial good I know Kingston Is.probably the standard???? Sorry not very computer savvy with what will fit this thing
Old 02-22-2024, 12:10 AM
srmmmm's Avatar
Non-ErrorChecking/Correcting.
Crucial is one of the best suppliers.
The Following User Says Thank You to srmmmm For This Useful Post:
Old 02-22-2024, 02:06 PM
KS circutguy's Avatar
Arrow
Best way to speed it up is to install a SSD drive instead of a old type spinning drive.
I like the Samsung units.
It will make a huge improvement if you don't have one.
https://www.newegg.com/samsung-500gb...SoldByNewegg=1
"There's nothing more unsatisfying than watching an electric car go down the dragstrip."
The Following User Says Thank You to KS circutguy For This Useful Post:
Old 02-22-2024, 02:12 PM
Is this it?
https://www.manua.ls/asus/cm1435/specifications
Old 02-22-2024, 06:57 PM
cnc's Avatar
cnc cnc is offline
This computer is really limited for how much I use ( mostly I pad like right now, convenience) it’s for car stuff some pics and other odds and ends I’m looking for the easiest option at my computer capabilities I ordered some ram last nite for like $50….but thanks for heads up if I ever I guess do anything else with it….
Old 02-22-2024, 06:59 PM
cnc's Avatar
cnc cnc is offline
I believe so from what I posted above….
Old 02-24-2024, 01:47 PM
Good info video on drive upgrades.
https://www.youtube.com/watch?v=EJfOPHTSQ7c
Old 02-24-2024, 02:47 PM
cnc's Avatar
cnc cnc is offline
So what would I need to do if I change hard drive to ssd with all the stuff I have on the hard drive that's in there now.....like windows 10, pics, resumes etc.....this sound like an interesting add on maybe ????? Like I said I'm notthat computer savvy....or take it to someone
Old 02-24-2024, 02:56 PM
Just clone the drive to the ssd.
free software
https://www.macrium.com/reflectfree
How to,
https://www.youtube.com/watch?v=3RgI2kGCvjM
make sure you 1st format the new ssd drive.
https://www.crucial.com/articles/abo...id-state-drive
Old 02-24-2024, 03:05 PM
cnc's Avatar
cnc cnc is offline
is the SSD u mentioned an appropriate upgrade for my system ??? Thats how much I dont know .....lol
Old 02-24-2024, 03:16 PM
Yes, have someone at your local computer shop do it if u lack the skills or possible a local kid that's a computer geek.
It will be worth the effort.
Old 02-24-2024, 03:29 PM
cnc's Avatar
cnc cnc is offline
Maybe Ill get my 6 year old grand daughter do it…lol…thanks very much for the input…
The Following User Says Thank You to cnc For This Useful Post:
Old 02-24-2024, 03:53 PM
cnc's Avatar
cnc cnc is offline
Just another quick question the ram I just bought is no issue if I ever do swap out to this SSD hard drive...
DDR3 1600 MHz CL11 Desktop Memory CT2K102464BD160B
Old 02-25-2024, 02:30 PM
You'll be fine.
No Issue.
