Old 10-28-2013, 05:10 PM
1966geeto 1966geeto is offline
Default Wood veneer and aluminum backer
I purchase a kit consisting of wood veneer and the aluminum backer plates I assumed they were the peel and stick but now that I have opened them they are not .What kind of glue is recommended to adhere these to the dash ? was thinking of using t 3 m contact adhisive what have you guys used ?
Old 11-04-2013, 09:35 AM
Nobody done this ?
Old 11-08-2013, 12:49 AM
Baseball12165 Baseball12165 is offline
is it a thin vinyl woodgrain?
Old 11-08-2013, 12:52 AM
If it is the thin vinyl woodgrain type most are peel and stick already. If yours is not -- be careful using the spray adhesive as it could penetrate the thin vinyl and deform it.
Old 10-05-2014, 11:08 PM
Shiny Shiny is offline
Default Woodgrain vinyl removal question
I need to redo the woodgrain vinyl on a 68-72 style console and as I read in other posts, mineral spirits are recommended to remove the old vinyl.
On the shifter bezel, the aluminum backing sheet is no longer stuck to the bezel, so I figured I can soak the whole sheet in a plastic bag filled with solvent overnight.
I also noticed the long edges of the backing sheet are lifted on the longer woodgrain.
Questions:
- What is the backing sheet made of? Aluminum or steel?
- Will mineral spirits also remove the metal backer from the bezel or is it possible to peel it without bending it?
- Is it best to buy die-cut vinyl and adhere to the metal backing sheet or does someone sell the vinyl already attached to the backer?
- Is there one vendor's vinyl that looks or fits better than others?
Old 10-06-2014, 01:17 AM
I redid the wood grain on my 68 firebird , for the console & the radio face but the stuff I used had a sticky surface os it , but to take it off I used my heat gun & it peeled right off & then I used brake clean to remove the rest of the glue tha was left over on the parts.
