Old 12-06-2016, 11:19 PM
Gtogrrr Gtogrrr is offline
Default Dougs or RARE
Hi All
I'm having a 600+ hp pump gas ported E head stroker motor built for my pro-touring stance 69 GTO. I've been reading the posts about header fit and issues. I have a 4 speed car. I'm really torn between going with header or losing some hp with manifolds. The car does sit pretty low. Would that eliminate the headers immediately? Am I ridiculous for considering manifolds based on my setup.
Bryan
Old 12-08-2016, 10:19 AM
David Jones's Avatar
Seems to me 600+ hp would want headers.
Lots of guys run headers on some pretty low cars. I don't think my Doug's are any lower than the RAIII manifold/Torque Tech downpipe setup I had on it to start with. The down pipes make a 90 degree bend right after the connection with the manifold which drops the pipe fairly low.
That's my experience with D Port.
Old 12-09-2016, 10:03 AM
Thanks for your input. I know it should really have headers but I was considering the manifolds to avoid the issues with headers in general , plus my car being low. I have time to think about it more. Thanks again
Old 12-12-2016, 02:27 PM
Bob's GTO Bob's GTO is offline
My 69 GTO has UMI suspension with Viking coil overs and dropped spindles. Saturday, we dropped in the 400 with Legend trans and I can tell you there's no way I would put headers on it. After everything was in place, I installed Ram Air manifolds and envision the downpipes will need to be tucked up as high as possible.
Old 12-12-2016, 09:54 PM
That's exactly what I am concerned with. I have an SC&C touring plus suspension with SPC tubular top and bottom a arms, tall ball joints, performance springs etc... Thanks for your input,
Old 01-13-2017, 03:13 PM
JLMounce JLMounce is offline
FWIW my '69 Firebird is fairly low. It has hotchkis 2" drop springs front and 3" rear. I have old 3 tube style headers in place and I don't have a lot of ground clearance issues with them. The subframe is the lowest part of the car.
That may differ completely on a GTO however.
-Jason
1969 Pontiac Firebird
Old 01-16-2017, 01:23 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
With the 2" drop, you have to at least consider giving up some of that 600hp for clearance issues. I would estimate 20-30hp. However, you could polish the hell out of the RA manifolds and gain a little of it back.
btw, If you decide to go the RA manifold route, I hope you take a look at the Max RA manifolds that we made. Same performance and fitment as RARE but a decent savings.
