I'm converting a 62 GP from Roto to a t-10 and am having a heck of a time finding a rear trans mount assembly. What is the possibility of moving the cross member forward enough to use the lower trans. mount boss of the t-10 along with a full rubber mount? Would this cause any complications? It surely seems like a better mounting setup. Thanks~
they show up on ebay quite often.Make sure your trans has the 5 holes shifter mounting tail housing.The tab on the trans mount goes into one of the unused holes.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
I've got the correct t-10, (date coded 11-61) with the hole for the mounting tab. I can't seem to bid fast enough on e-bay at the last 60 seconds when the bids go from $100 to $160 whew!Guess I should just put in a $500 bid from the gitgo that would shake them up! Anyway that's why I was wondering if the forward mount would work. Thanks for the food reply. Rich~
esnipe,set the max your willing to pay and forget it.Tom
Thanks Tom, I'll gladly try it.
If you move the cross member forward, you will have to do something with your emergency brake cables, one adjuster hooks to the cross member, There are a couple of other choices, 1. Use a long tailshaft T-10, 2. Contact Brad Duerst at Fabcraft, he is making a lot of stuff for 61-2 straight shift s, I think that he is making the piece that you are looking for. His email is bduerst@attg.net
http://kurtspontiac.homestead.com/Pre1964Pontiacs.html |
I recently did what you are suggesting on a 62 gp with a Muncie. Moved the crossmember up one hole and drilled new front holes. Fabbed a 1/4" steel plate, used the full rubber mount under the transmission. Had to shim slightly to correct pinion angle. Far better mount, I beleive, than the tailshaft mount. No problems so far - Lewis
Now that's what I like to see,- good ole Yankee enginuity! Thanks much~
The Following User Says Thank You to mgarblik For This Useful Post: | ||
This thread is old enough to vote FYI..
I used a chevelle crossmember and welded about 2" of plate to each side, now I can use a more typical trans mount and have cutouts for dual exhaust to clear.
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
