#41
the top HP on a dyno run does not always tell the whole story, attention must be paid to the whole power curve with intended useage in mind
.................................................. .No One Ever Escaped Tyranny By Compliance.............................. |
#42
![]() Quote:
#43
XR 276 224/230 .502/.510
OF 236/245 .570/574
#44
How much performance did you gain from your last cam change?
#45
OK,for grins here is the thread going from the 276 to SP.Tom
http://forums.maxperformanceinc.com/...d.php?t=804201 |
The Following User Says Thank You to tom s For This Useful Post: | ||
#46
Old Faithful to Old Faithful 2.0
Roughly 3 tenths and 3.5 mph.But a few things were changed. different shortblock 462 to 466 cu inch,much lighter pistons CP Carrillo's compression 10.25 to 10.8 heads reworked max flow 290cfm to 314cfm,new valvesprings retainers and keepers intake port matched to new heads
The Following User Says Thank You to ta man For This Useful Post: | ||
#47
![]() Quote:
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
Thread Tools | |
Display Modes | |
