Old 03-20-2014, 08:33 PM
4RSFEDGTO's Avatar
4RSFEDGTO 4RSFEDGTO is offline
Default NGK plug recommendation
Just wondering what NGK plug you guys that run NGK use with E-Heads and boost?
Mike Bright
Special thanks to Mark Luhn at Luhn Performance for all the help
Old 03-20-2014, 08:47 PM
bad69bird's Avatar
bad69bird bad69bird is offline
How much boost?
I would go with a #10....possibly a #11 depending on how much boost.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 03-20-2014, 09:04 PM
4RSFEDGTO's Avatar
Probably in the neighborhood of 18-22psi. Is that a R5671a-10 part #? I'm pretty sure the R5671a series plug is the one I need just want to verify what you guys are running. I will be on E-85 most likely but not 100% sure yet. Sorry forgot to mention that part.
Mike Bright
Old 03-20-2014, 09:14 PM
bad69bird's Avatar
Stock number 5820. And yes I would run a #10
Old 03-21-2014, 07:06 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
I run 8 on the street 9 if I run 18 to 20 psi
Old 03-21-2014, 08:23 PM
Torment's Avatar
Torment Torment is offline
-8's for me with ethanol. If you go colder make sure you have plenty of ignition to light it. Gdlk!
The secret to happiness is not getting what you want but rather, wanting what you have.
