Crankshaft????
What crankshaft are you guys running in turbo engines over 1500HP? I have an eagle 4340 crank now but I think I'm gonna need a stronger one for my setup...
Mike Bright Special thanks to Mark Luhn at Luhn Performance for all the help |
Moldex Crankshafts is what I have always owned but Bryant, Crower, Kellogg, would also work at that power level.
Crower is close to you Mike. Tom V.
GTO George |
The short block I am building now will have a Molnar crankshaft and a set of their turbo rods.
Don't know about 1500+ but this engine should make near 1500 if I put some boost to it. http://www.molnartechnologies.com/cr...m-pontiac.html |
Molnar is new to me. I could be wrong, but a forged Pontiac crank for less than $1,000 couldn't be of very "clean" 4340 could it?
http://bryantracing.com/products/ TOP OF THE HOME PAGE of the link above. "Crankshafts built with the highest quality USA made Timken Steel" FOR A REASON You asked for a 1500 HP Crankshaft Not a 600-850 HP crankshaft Tom V.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
I got one of the Scat 4.00" forgings from BOP after TomV had the metal tested and said it was pretty clean, hoping mine will take 1400 hp...
Tom Molnar the man behind Molnar technologies has a long history in the rod and crankshaft industry.
CP pistons did a review of the rods and added some history on Tom Molnar. The parts are china?/usa finished but look to have extra work performed. My engine machinist really likes them. http://cpbulletpistons.com/tom-molnar-rods-review.php |
GTOGeorge and Twooldgoats how much timing do you guys run?
Tom V.
I run 32*, locked.
Jim
http://www.molnartechnologies.com/ He was one of the "Brains" at Oliver Connecting Rods for years. Very good "How to make it correctly" kind of a hardware guy. He offers his own connecting rods but I am sure he specs out the metal (Chinese) before he buys it for both his Rods and his Crankshafts. Then he does other mods to the parts: "Our 4340 forged crankshafts are heat treated to increase tensile strength, shot peened to increase fatigue life, nitrided for wear resistance and 100% mag particle inspected to ensure against cracks." So his stuff could be as good or better than the SCAT stuff (or not quite as good) but the effort he puts into the other operations (above) suggests that he would not skimp of dirty steel. The fact that the CP Pistons guys like his stuff says that the parts are pretty good. CP Pistons and Carrillo Rods are one company ownership. Carrillo Rods are very good. Just my thoughts on Tom Molnars stuff. Tom V.
I was increasing it last year and ended up around 29 degrees....I tried 30 but it didn't seem to do any good! Remember every combo is different.
GTO George |
Here's a little info about Molnar Technologies. Tom Molnar was the Metallurgist and engineer for Oliver Rods and Cranks for over 20 years. He was the founder of K-1 Technologies and now he has opened his doors under his own name. Molnar Crankshafts are 4340 steel, core hardened and tempered to reduce stress and optimize tensile strength. The crankshafts are made with a nitrating process for hardening rather than induction heat treated. This eliminates any softening between the journals and any post running deformation. Forged and Billet 4340 Steel Crankshafts. Material properties are closely monitored for optimum performance. Counterweight placements designed for improved crankshaft performance. .125" fillet radii. Nitrated for improved bearing life. Straight hole oiling system for better lubrication. Size tolerances held to +/- .0001”. (1/10,000) Molnar crankshafts also feature straight oil holes for the best oiling to the rod journals to insure you get the best crank for your money. Each Molnar crankshaft is magnetic particle inspected and held to a maximum tolerance of .0002” journal dimension. Counterweights are placed for optimal load reduction and ease of balancing making less work for you or your builder. |
Thanks for the info! GTO George |
Jim
