Old 03-22-2022, 05:20 PM
napster's Avatar
napster napster is offline
Default New Engine Combination for '78 T/A
I have a '78 T/A currently with a 406 with 6X#4 heads 9.45 to 1, with the Comp XE274H-10 cam and last Doug's headers with 1 7/8th primaries and 3" collectors. Also, has 1.5 roller tip rockers. Behind it is a TCI 700R4 with 3.73's. I'm thinking of changing the engine as follows:
Put a 427 stroker kit in it for 433 cubes. Use a set of #48 heads with 9.9 to 1 compression. One of two cams will be used that I have still in the box from Butler Performance. Both are custom grind for Butler. First is HR with 230/236 @.050, LSA @ 112. Second is HR with 236/242 @ .050, LSA @ 112. I like the second one with 1.65 roller rockers. Will use the same headers, Transmission and Rear.
Opinions and guesses on HP/TQ. Will not be for racing.
Thanks in advance.
Old 03-23-2022, 07:39 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
Unless you do some work on those heads BEST your going to get MIGHT be 420/450 hp or tq....gotta move air to make it happen.
The Following User Says Thank You to 67Fbird For This Useful Post:
Old 03-23-2022, 02:14 PM
HWYSTR455's Avatar
The 4.25 stroker cranks are the same price or less, might as well go big.
Totally agree on the heads, you can get the speedmaster ones if you're on a budget.
Old 03-23-2022, 02:24 PM
25stevem's Avatar
25stevem 25stevem is offline
How much lift will you have with the 1.65 on either cam, or at least state how much lift either cam has with 1.5 rockers.
If you going for a true 9.9 comp with iron heads I would run the bigger cam.
I do stuff for reasons.
Old 03-23-2022, 02:38 PM
napster's Avatar
Here are the cam cards.
There is a budget and I want to use the heads I have. Porting will be done, but to what extent needs to be discussed with the engine builder.
ID:	586955   Click image for larger version
Old 03-23-2022, 04:49 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Attached are dyno sheets from two engines, both are 455's. First is 8.8 to 1 compression with Super Duty heads, the second is just under 10 to 1 with iron "D" ports. The first dyno run is the smaller 230/236/112 HR, the second is the larger one. The third pic is the cam I used in the first engine. It is going to be the same as the Butler HR cam.
I don't think you'd be off that much in power with the 428 based build topped with #48 heads.......
ID:	586976   Click image for larger version
Name:	Super Duty (1).JPG
Old 03-23-2022, 05:13 PM
25stevem's Avatar
The valve lift limit with the stock valve installed height of those # 48 heads is .480”.
Both of cam picks of yours even just with 1.5 rockers no less 1.65 rockers calls for having the spring pockets cut deeper for more installed height or new taller valves to be used.
Old 03-23-2022, 05:26 PM
napster's Avatar
Cliff and Steve,
Thanks for the information. Very helpful.
Jim
Old 03-23-2022, 05:34 PM
25stevem's Avatar
Welcome!
