Old 03-22-2022, 06:35 PM
alanmay0 alanmay0 is offline
Default carburetor spacer
Hello I recently bought a 67 GTO and it had an elderbrock aluminum intake and carb on it. I bought a correct 67 intake manifold and then I also bought a quadrajet carb for it. The carb is off of a 455 oldsmobile, i believe. Anyway the carb does not have a vacuum port in the rear for the power brakes. So I am thinking of getting a aluminum spacer with a port to solve my problem. Thing is there are so many spacers I am not sure which one will work with the quadrajet. any thoughts?
thanks
Old 03-22-2022, 07:15 PM
PAUL K's Avatar
PAUL K PAUL K is offline
A four hole spacer would probably be the better choice for a stock type engine. You might gain a little bit of power by opening up the divider between the secondary holes.
Go fast, see Elvis!
Old 03-22-2022, 07:16 PM
any brand or part number?
Old 03-22-2022, 08:16 PM
F ROCK's Avatar
F ROCK F ROCK is offline
mine uses a port on the intake, in front of the carb, for brakes.
Old 03-22-2022, 08:43 PM
ZeGermanHam's Avatar
If I was in the market for a carb spacer, I'd probably get one from Wilson Manifolds: https://www.wilsonmanifolds.com/coll...red-carburetor
1998 BMW 328is (track rat)
Old 03-22-2022, 11:30 PM
Cliff R's Avatar
Cliff R Cliff R is offline
The correct 1967 intake will have the "hot slot" across the front. It requires the correct gasket and stainless steel heat shield over it. You will need that configuration unless the holes at the end of the U shaped channel are blocked off, and even then without the correct gasket you may end up with a vacuum leak as one side of the slot extends out pretty far and only a few available gaskets will effectively seal it off.
Not sure which Olds carb you are trying to use, part number would help, but they are easily drilled and tapped for 1/8" NPT thread to add an 1/8"NPT to 3/8" hose fitting so not spacer would be needed.........Cliff
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
Old 03-23-2022, 04:54 AM
Kenth's Avatar
Kenth Kenth is offline
That port, and the port below, is for the PCV-system, NOT the brakes.
Using one of these ports your brakes will have reduced vacuum from only four cylnders.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-23-2022, 05:02 AM
Kenth's Avatar
thanks
Do not make it more difficult than necessary.
Drill a hole in the back of the throttleplate and thread 1/8" NPS for a 1/8" NPT fitting.
OR, use the PCV port on carb for the power brakes. No drilling needed.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 03-23-2022, 06:30 AM
Jeff Hamlin's Avatar
Thumbs up EDELBROCK CARB ONTO Q-JET MAN
This is what I needed on a current project, to mount the Ed carb onto the factory Q-Jet manifold.
Name:	SPACER REQUIREMENTS 3.jpg
ID:	586934   Click image for larger version
Name:	SPACER REQUIREMENTS 4.jpg
ID:	586935   Click image for larger version
Name:	SPACER REQUIREMENTS 5.jpg
Old 03-23-2022, 03:33 PM
Kenth's Avatar
Not needed to mount an Olds Qjet on a 1967 GTO intake.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 03-23-2022, 04:16 PM
ok what are you calling the throttle plate. you talking about the carburetor itself?
Old 03-23-2022, 04:18 PM
It is needed if I want to run my power brake booster from the rear of the carb. Do not want to run a rubber hose around the back of the carb to the front where there are vacuum ports. Would look like crap to me.
Old 03-23-2022, 04:40 PM
Cliff R's Avatar
Your answer and solution was in my first response. I also mentioned that a carburetor part number would help, never got one.
The Olds baseplate is not drilled and tapped, but the passage is there. Drill and tap for 1/8" NPT threads directly into the back of the baseplate in the center. It's not fussy. Then tap for 1/8" NPT threads and install an 1/8"NPT to 3/8" hose fitting, run a 3/8" hose to the brake booster.....done.....
The Following User Says Thank You to Cliff R For This Useful Post:
Old 03-23-2022, 06:13 PM
Red face
My bad, misread his post.
Old 03-23-2022, 09:44 PM
OK the carburetor # is 17056252. I have attached a few pictures of the carb so that you may better understand my situation. At the back of the carb there is one vacuum that goes to whatever it is. If you look at the picture of the car upside down you can see that it would be very difficult to add a vacuum port. I do not know how large of a vacuum hose you need going to the brake booster. It is a 3/8 hose or a 1/2" hose or something else? How large of a diameter hose do you need to power the brake booster? Let me know what else you need.
By the way I will be removing the large fuel filter sticking out from the front of the carb so that I can use the original fuel line. I will but a inline fuel filter in. What can or do i need to bring that huge 1" diameter opening down to the size of the fuel line. If anyone knows.
alan
ID:	587018   Click image for larger version
ID:	587019   Click image for larger version
ID:	587020   Click image for larger version
Old 03-23-2022, 11:25 PM
Tim Corcoran's Avatar
You need to drill and tap a hole in the rear center of the base plate of the carb to 1/8 pipe threads. The hose for your power brakes is 3/8" and there is a fitting that screws into the carb (1/8" NPT) and a 3/8 barbed on the other end for the power brake hose.
Tim Corcoran
Old 03-24-2022, 04:37 AM
Kenth's Avatar
A picture of the throttle plate and a link for short fuel inlet fitting an related gasket, filter and spring. No need for external filter.
The threads in throttle plate for the 1/8" NPT (National Pipe Tapered) 11/32" power brake hose fitting are 1/8" NPS (National Pipe Straight).
https://www.carburetion.com/Products...x?Part=CUD3914
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 03-24-2022, 07:15 AM
Cliff R's Avatar
I sell those here and would use the high flow micro-screen fuel filter instead of the small paper one.
I would NOT for any reason run an in-line filter with rubber hose and clamps, very dangerous on the pressure side of the fuel system..........
